ᐅ Are there any tips for modifying Ikea HEMNES furniture in rental apartments?
Created on: 9 Nov 2023 19:23
Mathis8
I will soon be moving into a new rental apartment and plan to bring some Ikea Hemnes furniture with me. Since this furniture is often quite solid and not always ideally suited to rental conditions like smaller rooms, fixed wall colors, or a lack of building permits/planning permission for drilling, I’m wondering if anyone has tips on how to customize Hemnes furniture individually without major structural changes or damage to the apartment while still making practical use of it? I’m thinking, for example, of ideas such as surface treatments, alternative assembly methods, or solutions for wall mounting without drilling. Maybe there are also proven tricks to visually adapt the furniture to the room without completely rebuilding it. I would really appreciate practical advice or personal experiences.
In summary:
- Hemnes furniture is sturdy, but its back panel fixing can be problematic in rental properties where drilling is not allowed.
- Adhesive and hook-and-loop solutions are practical but usually have limited load capacity.
- Surface modifications using removable chalk paint or furniture films are possible but require preliminary tests for compatibility.
- Floor protection is essential to avoid damage during moving.
Those who want to change colors temporarily should also consider that films can usually be replaced more easily and frequently than paint.
For a more secure wall mounting without drilling, spacer guides or intermediate constructions are often necessary, within the boundaries of tenant law.
Thank you very much for the detailed and very helpful advice!
I have been thinking again: What about alternative panels or additions instead of the standard back panel? Has anyone, for example, experimented with thinner shelves or custom constructions under the HEMNES series to make the furniture more flexible without losing the original stability? Also possible in rental apartments without structural changes?
I can fully understand how frustrating all of this can be, especially when you want to enjoy beautiful furniture without damaging your apartment.
I have tried using lightweight edge profiles to completely replace or at least reduce the impact of back panels. Sometimes simple, thin wooden panels, cut to size and placed without screws, are enough to make the piece of furniture easier to modify. However, this does not always provide the same stability as the original back panel.
Sometimes it also helps to position the furniture loosely against the wall and ensure stability through targeted weight distribution (e.g., books in the lower half).
elgla schrieb:
Sometimes it helps to place the furniture loosely against the wall and ensure stability by carefully distributing weight (for example, placing books in the lower half).That sounds very practical. Especially with tall cabinets, I sometimes worry they might tip over if they aren’t properly secured. Do you have any experience with specific anti-tip devices that can be used without restrictions in rental apartments? I mean solutions that are technically effective but can also be removed later without leaving any damage.
