ᐅ How can I prevent BILLY shelves from warping?
Created on: 19 Mar 2022 08:27
MUDOLEN
MUDOLEN
19 Mar 2022 08:27
A few months ago, I bought several BILLY bookcases from IKEA because they are affordable and basically meet my requirements for storage and design. However, I am now facing the problem that some shelves and side panels have warped, which unfortunately affects both stability and appearance. My question is therefore: What methods or measures do you recommend to protect BILLY bookcases from warping in the long term?
I am thinking, for example, about the type of wall fixing, additional reinforcements used, or special care and storage of the bookcases. Perhaps the location (room climate, humidity) also plays a role? I look forward to practical tips that can minimize or prevent this problem over time.
Marlenepa
19 Mar 2022 09:03
Hello MUDOLEN,
First of all, regarding your very good question: warping in BILLY shelves is indeed a common issue, especially when wood-based materials are exposed to moisture.
MUDOLEN schrieb:
Maybe the location (indoor climate, humidity) also plays a role?
Exactly, the indoor climate is extremely important. It’s best not to place the shelves directly against an exterior wall, as there is often more moisture and temperature fluctuations there. An ideal location is a dry, well-ventilated room without direct sunlight.
It is also important to always install the shelves using the included wall mounting brackets. These prevent the shelf from twisting or wobbling, which places permanent stress on the boards.
Some have had good experiences by adding extra screws or small metal brackets to the back panel to increase stability. However, this must be done very carefully to avoid damaging the shelf.
Additionally, I recommend occasionally reducing the load on the shelves, meaning not overstuffing them with too much weight all the time, and if they won’t be used for a longer period, preferably leaving them completely empty. The material properties of MDF or particleboard can react to continuous load with slight deformation.
floga
19 Mar 2022 11:47
Hello MUDOLEN,
I’m very familiar with this issue, as I also have several BILLY shelves in my apartment, and warping can indeed be really annoying over time.
What worked very well for me was placing the shelves on small rubber feet or furniture glides instead of directly on the usually cold and sometimes damp floor. This reduces the amount of moisture that can reach the sides of the shelves from below.
Marlenepa schrieb:
Some people have also had good experiences adding extra screws or small metal brackets to the back panel of the shelf
At first, I was hesitant about using screws too, but I went ahead carefully — the important thing is that the back panel is always firmly secured. Small cross braces made of metal or even wooden strips at the back can make a big difference, especially with larger shelves.
Additionally, I have kept the humidity consistently around 50% with ventilation, which I find ideal for wood-based materials.
If possible, I would also choose a location in a room that is not exposed to strong temperature fluctuations, for example, not right next to radiators or windows.
baAlejandr
20 Mar 2022 10:19
Good morning,
to answer the question about how to protect BILLY shelves from warping, here is a summary of the most important points:
- Use wall mounting: Without wall brackets, the shelf is more likely to warp.
- Add reinforcements: Small metal brackets on the back panel or side panels significantly increase stiffness.
- Protect from moisture: Never place directly on cold or damp floors; rubber pads or felt gliders can help.
- Optimal indoor climate: 40-60% humidity and a consistent temperature are ideal.
- Distribute load evenly: Avoid placing excessive weight on individual shelves.
MUDOLEN schrieb:
What methods or measures can you recommend to protect BILLY shelves from warping permanently?
If you are handy, it is advisable to replace or reinforce the back panels with stronger material. This noticeably reduces warping. Applying a protective coating with water-resistant paint or a special sealant could also help stabilize the panels against moisture.
By the way: BILLY shelves are generally designed for private use, not for carrying extreme loads or withstanding drastic climate changes.
Z
zarlu
21 Mar 2022 15:55
I’d like to offer a slightly different perspective here:
Marlenepa schrieb:
Some have also had good experiences using additional screws or small metal brackets on the back panel of the shelf
Honestly, I find such modifications rather counterproductive, since BILLY is a mass-produced item designed specifically for easy assembly without much effort. If you start adding screws and brackets, you risk causing instability in other parts of the structure or creating unsightly stress on the materials.
Moreover, warping is often not a real design flaw but more a result of the materials used, which are affordable but also sensitive to moisture. Therefore, I would generally focus on ensuring the shelf is not placed in damp or poorly climate-controlled areas rather than trying to reinforce it in a complicated way.
If someone really wants something stable, they should consider alternative shelving systems made of solid wood or metal, which are generally less prone to warping.
MUDOLEN schrieb:
What methods or measures would you recommend to permanently prevent BILLY shelves from warping?
My advice: rather change the “rules” than constantly adding reinforcements inside the shelf. Choosing good locations, minimizing moisture, and possibly using a thin protective sheet between the shelf and the wall can be much more effective than adding screws.
