ᐅ How can I protect Billy bookcases from scratches?
Created on: 1 Jul 2020 18:37
Mattto
Mattto
1 Jul 2020 18:37
Hello everyone, I’m looking for advice on how to best protect my Billy shelves from scratches. Although I have handled the shelves carefully, daily use and rearranging have caused fine scratches on the surfaces, especially on the shelves and side panels. Could anyone recommend effective methods or products to help preserve the surface? I’m interested to know if there are special protective films, coatings, or other practical tips. Furthermore, I would also like to learn about long-term solutions that maintain the value of the shelves without negatively changing the typical appearance of IKEA furniture. Thanks in advance for your helpful suggestions!
Surela
1 Jul 2020 19:02
Hello Mattto,
I understand that you want to protect your Billy shelves in the long term—they are not exactly cheap and should be kept in good condition as much as possible. As a first step, I generally recommend thoroughly cleaning the shelf surfaces while avoiding harsh cleaning agents, as these could damage the finish.
To protect against scratches, I often use a combination of applying a special, thin protective film that is transparent and self-adhesive, and avoiding sharp objects directly on the surface. There are large-format protective films that can be cut to size—these are very easy to apply to shelves and side panels and protect against scratches from book edges, decorations, or occasional shifting.
Mattto schrieb:
ob es spezielle Schutzfolien, Lackierungen oder andere praktische Tipps gibt
When it comes to painting, caution is needed: Billy shelves have a melamine resin surface, which paint does not always adhere to well. If you want to paint, a special primer or paint formulated for melamine is recommended, but this will eventually change the surface feel—so it will slightly alter the typical Ikea look.
Another idea that works well for some is placing a thin, non-slip felt or foam rubber pad under items. This helps reduce scratches caused by movement.
What exactly do you use the shelves for? Are there often heavy books inside, or mostly decorative items that get moved? Are there small children or pets who might unintentionally cause scratches on the surface? This information would help tailor the solution precisely.
JULIANNALO
2 Jul 2020 09:56
I always use self-adhesive transparent films, which are affordable and easy to apply. Alternatively, I have placed felt pads on shelves to prevent anything from scratching the surface directly.
danial60
2 Jul 2020 11:17
Hi Mattto,
to answer your question in more detail, I’d like to explain step-by-step how you can effectively protect your Billy shelves from scratches:
1. Clean before protection: Remove dust and grease by wiping with a microfiber cloth and a mild cleaning agent. This is important so that protective films or coatings adhere better.
2. Lightly sand the surface (optional): If you plan to paint, gently sand the surface with fine sandpaper (320 grit) to improve paint adhesion. Be careful not to sand too much, as this can damage the melamine coating.
3. Apply protective film: Applying transparent, self-adhesive protective film from the automotive sector (e.g., paint protection films) is an excellent option. These films are also very durable and easy to clean.
4. Painting (if desired): For painting, I recommend water-based acrylic paints, which are particularly suitable for furniture. Look for products suitable for plastic or melamine resin surfaces. Apply in thin layers and allow each coat to dry thoroughly.
5. Use felt pads or foam rubber: Place these under objects to protect the surface and prevent damage from movement.
6. Avoid direct contact with sharp objects: For example, be careful not to place sharp-edged decorative items directly on the shelves.
Surela schrieb:
Gibt es kleinere Kinder oder Tiere, die mit der Oberfläche eher unbeabsichtigt Kratzer verursachen?
An important point! If you have pets that scratch furniture with their claws, an additional protective barrier is almost unavoidable.
Could you also explain how often you move the shelves or how heavily they are used daily? That would help to give you more precise recommendations!
