I recently installed an Ikea PAX wardrobe at home, but I’m concerned about the safety of my small children. The doors of the PAX system are quite easy to open, which can be problematic with young kids around – they might access sensitive or dangerous items or even get their fingers caught.
My question is: What options are available to childproof the Ikea PAX doors? I’m especially interested in practical solutions that are either compatible with the existing materials or can be implemented without major modifications. Which types of locks or safety mechanisms are recommended and have proven effective in everyday use?
I would also appreciate any tips from those who have had similar experiences about solutions that are easy to install, durable, and efficient. It’s important to me that the doors become child-safe but remain easy for adults to use.
Thank you in advance!
Hi Thomas,
I recommend adhesive child safety locks that are applied directly to the door. There are special cabinet locks designed to be installed inside, making it difficult for children to open but easy for adults to operate.
Alternatively, you can use magnetic catches from the hardware store, which are both invisible and effective.
Hello Thomas39,
To make the Ikea PAX doors childproof, it is important that the chosen solution neither limits functionality for adults nor affects the stability of the doors.
The following methods have proven to be practical:
- Magnetic child safety locks: These are installed on the inside and require a special key or magnet to open the door. This offers good protection since children cannot recognize or operate the mechanism.
- External locking clips or cabinet locks attached with adhesive or screws. It is important to watch out for residue when removing them.
- Child safety bolts mounted at the top of the door frame that block the doors.
- Specifically for PAX: IKEA offers child safety locks for other cabinets that are mostly compatible, although not all models have been tested.
I also recommend checking the door mechanism for any weak points before installation and choosing a solution that is easy to install and does not create gaps where children could trap their fingers.
I hope this helps you with your decision.
Hello Thomas39,
I would like to provide a more detailed guide on how to significantly improve child safety on Ikea PAX doors. I will cover the installation process and the selection of safety devices to ensure they work well in daily use.
1. Analyze the Type of Door
First, identify which type of doors you have (e.g., hinged doors, folding doors, or sliding doors). The type influences which safety devices are most suitable.
2. Choosing the Appropriate Child Safety Device
- For hinged doors, magnetic catches or clamp/latch mechanisms mounted inside the door frame work best.
- Folding doors can be secured with special clip-on or adhesive locks that prevent them from folding open.
- For PAX sliding doors, locks installed on the upper track system are ideal to prevent uncontrolled sliding.
3. Installation Tip
Make sure the safety devices are installed so that adults can operate them with some practice, while children cannot open them without tools or assistance.
4. Avoid Common Mistakes
- Avoid adhesive locks in areas with heavy use, as the adhesive may weaken over time.
- Regularly check that all catches are still firmly attached and that no small parts have come loose.
5. Alternative: Replace Inner Door Handles with Plastic Ones
Some parents replace the handles with designs that are harder for children to grip.
In short: Magnetic child locks inside the door are often the best option, combined with regular checks. This protects the cabinet and extends its durability.
If you like, I can also provide exact product recommendations and installation steps.
3. Installation Tip
