Good morning everyone,
I recently purchased several IKEA Hemnes furniture pieces (e.g., dressers and cabinets) and am looking for ways to make them child-safe through modifications or adjustments. Specifically, I want to adapt these often quite heavy pieces to a household with small children, to prevent tipping or injuries from sharp edges.
My questions are:
- What precautions and modifications are practical and effective for making the Hemnes series child-safe?
- Are there any specific fittings, anchors, or protective measures you would recommend?
- How can stability be improved without limiting usability?
I understand that IKEA Hemnes is not primarily marketed as children’s furniture, but with the right modifications, these pieces should still be safe.
I appreciate any experiences, tips, or instructions you can share!
Elke
My questions are:
Elke
Hello Elke,
your question about making IKEA Hemnes furniture child-safe is very well asked – you have clearly outlined the requirements.
Here is a structured overview of how you can proceed:
- Install anti-tip devices: For Hemnes dressers and cabinets, wall mounting with the included or special wall anchors is highly recommended. These prevent tipping if children pull themselves up.
- Attach edge protectors: For sharp edges, simply apply transparent corner protectors from a hardware store. These are flexible and can be attached almost invisibly.
- Secure drawers and doors: Child safety locks for drawers and doors prevent pinching and unwanted opening.
- Improve stability: Hemnes furniture is often reinforced with wood screws, especially at the joints of the side panels and back panels. Make sure to tighten the supplied screws properly, as loose connections significantly reduce stability.
- Consider load distribution: Place heavy items in the lower sections so the furniture’s center of gravity remains low.
If you want, I can also provide a small guide with suitable anchor types and installation instructions.
LOGEMIN
LOGEMIN
LOGEMIN schrieb:
Hemnes furniture is often reinforced with wood screws, especially at the joints between side panels and back panels. Make sure to tighten the included screws properly, as loose connections significantly reduce stability.That is correct, but I wonder if a simple “just screw it on” approach is really the best solution here. Some Hemnes models have rather thin panels, and using overly strong screws risks splitting the wood or weakening the furniture’s structure.
Therefore, I strongly recommend using high-quality wood screws, ideally with countersunk heads, and pre-drilling pilot holes. It’s also important to ensure the areas being reinforced are truly load-bearing — when in doubt, stabilize on the inside of the side panels rather than the front.
Has anyone had experience with alternatives to wood screws? For example, metal brackets that can be attached inside without affecting the appearance?
Also: the anti-tip protection is of course essential, but how reliable are the supplied spacers and wall plugs when dealing with different types of wall materials? Are there better solutions for that?
kasan schrieb:
Does anyone have experience with alternatives to wood screws? For example, metal brackets that can be installed inside without affecting the appearance?I recently studied this topic in detail, as I also childproofed several Hemnes dressers. Metal brackets (such as corner connectors used in furniture construction) are indeed a very good option for reinforcing the structure. Important notes:
- The brackets should be made of stainless steel to prevent corrosion over time.
- Ideally, mount them on the inside corners where they are not visible from the outside.
- Be sure to pre-drill with a thin drill bit before screwing to avoid damaging the material.
- Avoid screws that are too long to prevent penetrating through the panels.
- Combine this with attaching a sturdy plywood back panel, which you secure with additional screws. This greatly increases overall rigidity.
A tip: For tipping protection, you can use so-called safety cabinet straps with metal bands that are screwed to the wall and the furniture. These are more durable than simple fabric straps.
Would you like exact measurements and sources? I can also provide details on suitable types of screws.
Z
zarHenning3 Jan 2024 10:40Tip-over protection is mandatory. Use sturdy wall anchors, not simple adhesive types. Flexible foam edge protectors provide good protection. Drawer locks help prevent pinching injuries. Pre-drill screws!
kasan schrieb:
Has anyone had experience with alternatives to wood screws? For example, metal brackets that can be installed on the inside without affecting the appearance?Thank you, that’s an important point. The furniture is relatively thin, so I don’t want to take any risks. Metal brackets on the inner sides sound good and would be discreet visually. When do you think these brackets make sense — only for newly assembled furniture or also for retrofitting older pieces?
My goal is to be able to use the dressers for years without them becoming loose.
Regarding the wall material: we mostly have concrete walls and some drywall areas. Are there proven fixing methods that are robust? The supplied anchors seem quite fragile in drywall.
I appreciate any tips.
