ᐅ How can I modify IKEA Hemnes furniture to make it child-safe?
Created on: 3 Jan 2024 08:17
eljean
Good morning everyone,
I recently purchased several IKEA Hemnes furniture pieces (e.g., dressers and cabinets) and am looking for ways to make them child-safe through modifications or adjustments. Specifically, I want to adapt these often quite heavy pieces to a household with small children, to prevent tipping or injuries from sharp edges.
My questions are:
- What precautions and modifications are practical and effective for making the Hemnes series child-safe?
- Are there any specific fittings, anchors, or protective measures you would recommend?
- How can stability be improved without limiting usability?
I understand that IKEA Hemnes is not primarily marketed as children’s furniture, but with the right modifications, these pieces should still be safe.
I appreciate any experiences, tips, or instructions you can share!
Elke
Fitigu
3 Jan 2024 14:09
eljean schrieb:
Regarding wall materials: We mostly have concrete walls and some drywall areas. Are there proven fastening methods that are sturdy?
For concrete walls, heavy-duty anchors should be used, such as metal expansion anchors or chemical anchors with epoxy resin. These provide long-lasting strong hold and are secure against pulling and vibration.
For drywall:
- Use special drywall anchors that expand behind the gypsum board or have toggle mechanisms.
- Alternatively, metal hollow wall anchors are recommended.
- The load capacity is lower than with concrete but is definitely sufficient for lighter furniture (or if you place heavier loads at the bottom).
Additionally, attach furniture at multiple points on the wall rather than just one to better distribute the load.
For anti-tip straps in drywall, the cables or straps should have good tensile strength, and the attachment points should be designed to spread the load over a larger area.
In summary:
- Concrete: heavy-duty anchors
- Drywall: special drywall anchors or metal hollow wall anchors
Check the maximum load capacity of the anchors before purchase and use a safety factor.
mauka
4 Jan 2024 09:17
Good morning everyone! ?
I’d like to add a quick tip: For edge protection, you can easily use silicone corner guards or flexible rubber edge protectors – not only are they very effective, but they also look better than hard plastic protectors.
I used this on my Hemnes dressers, and since then my little rascal hasn’t scraped her knees on the corners. It also acts almost like a small cushioning.
Another tip for the drawers: I installed special magnetic locks that make it nearly impossible for little ones to open them, but are very easy for adults to operate.
This way, you can combine safety and convenience.
Good luck with your renovations! ?
barle
4 Jan 2024 11:56
To prevent tipping, always secure to the wall, preferably at the top using metal brackets and heavy-duty anchors. Edge protection can be done with foam profiles, and drawers can be secured with child safety locks to prevent opening.
eljean
5 Jan 2024 07:29
Fitigu schrieb:
For anti-tip safety devices on drywall, the cable or strap material should have good tensile strength, and the anchor points should be designed with a sufficiently large surface area.
Thanks for the information about drywall – that makes sense to me. I will definitely pay attention to using appropriate anchors and enough fastening points.
Regarding the general question about stability: Would it be advisable to reinforce the joints with metal brackets on older Hemnes wardrobes that have become a bit loose before attaching the anti-tip devices?
I am just unsure whether adding metal brackets afterward could damage the furniture. Has anyone had experience with retrofitting like this?
The main goal is long-term safety in the children’s room without compromising the appearance.
