Hello everyone, I recently bought the IKEA Brimnes chest of drawers and am looking for ways to make it as childproof as possible. My children are very curious and show great interest in opening all the drawers – which is not always safe, as some of them contain sharp objects or delicate items. I know that IKEA does not offer specific child safety locks for the Brimnes drawers, so I have been considering alternative solutions. I am particularly interested in practical, easy-to-install and removable locks that ideally do not leave permanent marks on the furniture if I want to take them off later. Does anyone have experience or recommendations for childproof locks, such as latches, locks, or other mechanisms, specifically for the Brimnes drawers? Which solutions have proven to be durable and at the same time child-friendly? Any ideas or experiences would be very helpful, thank you in advance!
Hey blaka! It’s great that you’re approaching this so thoroughly! 😃 I also had an issue with my IKEA drawers and solved it with some simple but brilliant child safety locks. I recommend magnetic child safety locks that you attach inside the drawers. They’re really practical because they’re completely invisible – from the outside, no one can see that anything is locked! 👍 The cool thing is: these locks can only be released with a special magnet, which you simply hold against them to open. Very straightforward and easy to install without causing much damage to the furniture. The drawers stay securely closed, parents are happy, and kids, too, since you don’t have to deal with complicated locks. If that doesn’t work, I can also recommend latch locks that you attach on the outside, but they aren’t quite as neat visually. In any case: don’t worry, there are great solutions out there! Good luck securing everything, you’ve got this! 😄
@blaka, thank you for the precise question. When making the IKEA BRIMNES drawers childproof, it is important to consider not only functionality but also material compatibility and installation method. The BRIMNES features flat drawer fronts with recessed handles, which poses a challenge for external locks. I recommend the following options: - Magnetic child locks mounted inside the sidewalls; they provide a secure lock without visible components. - Lever locks installed on the inside top of the drawers that make opening difficult for children but remain easy for adults. - Alternative clip-on or latch systems that can be glued or screwed to the drawer front are less recommended due to potential marks. It is important to check before installation that the fasteners used do not damage the material and can be removed without leaving residue if necessary. Additionally, I advise storing drawer contents securely out of reach of children (e.g., sharp objects separately), as mechanical safety devices always carry some residual risk. I hope these suggestions are helpful to you.
Hello blaka, here is a brief overview of how to best implement child safety for the BRIMNES drawers. First, a short introduction: The main issue is that the BRIMNES drawers do not have traditional handles but recessed grips, which means conventional locking systems often do not fit well. Therefore, it is advisable to install the locks on the inside.
Step 1: Choosing the right child safety lock – Magnetic locks work very well as they can be mounted underneath or on the side of the drawer. Advantage: they are invisible and easy to operate with the appropriate magnetic key.
Step 2: Preparing for installation – Clean the surface thoroughly where the lock will be attached to ensure adhesive bonds hold firmly. Some systems require screws; in this case, proceed carefully to avoid damaging the furniture.
Step 3: Installation – Attach the lock inside on the side panels of the drawer so it cannot be opened without the magnet.
Step 4: Testing and long-term check – Regularly check that the locks are still firmly attached and have not loosened. Avoid using harsh chemicals when cleaning that could degrade the adhesive.
Step 5: Alternative options if needed – Child safety systems with levers or latches mounted on the outside are less recommended as they can affect the appearance.
Summary: The best child safety solution for BRIMNES drawers is an internally mounted magnetic system that neither spoils the look nor leaves marks.
I hope this step-by-step guide is helpful! Good luck!
