ᐅ How can I make BILLY shelves silent?
Created on: 31 May 2019 09:37
Filelis
Hello everyone, I have some Billy shelves from IKEA in my living room, and I’ve increasingly noticed that the shelves creak and squeak quite noticeably when moved or when loading and unloading them. This is especially annoying when I want to get something from the shelf late in the evening or when children are in the room and we want to keep noise to a minimum.
I’m particularly interested in how to make these BILLY shelves silent without having to take them completely apart. Are there proven methods or materials that effectively reduce the creaking? Which components are especially relevant (e.g., joints, shelves, back panel)? Maybe someone also knows about special lubricants or small construction adjustments that can help.
Thanks in advance for your tips and experiences!
TEBILO
2 Jun 2019 14:51
Hello Filelis, first it is helpful to precisely locate the sources of the noise. Typically, the sounds in BILLY shelves are caused by the following factors:
1. The connection between the back panel and the carcass (usually a thin fiberboard that can easily vibrate).
2. The shelves resting on wooden battens or metal pins.
3. The fasteners (screws and dowels) that allow movement due to play.
Step-by-step guide to reduce noise:
- Remove the shelves and check the support surfaces for roughness or unevenness.
- Lightly sand the edges to remove any excess paint or wood splinters.
- Apply thin strips of foam rubber or felt to the support surfaces to minimize friction.
- Glue the back panel with wood glue (carefully and sparingly) to reduce its vibrations. Make sure to apply the glue evenly to avoid warping.
- Tighten all screws and connections, and check the fit of the dowels.
- Optional: Lubricate metal contacts if needed with a PTFE-based dry lubricant.
Before gluing the back panel, I recommend assembling the shelf temporarily and carefully listening to identify exactly where the noise occurs.
In conclusion: Completely eliminating the noise is often difficult, but these measures can significantly reduce its intensity. If noises persist, a closer examination of the floor contact points and the shelf’s wobbling movements would be necessary.
Is the shelf standing on a hard or soft floor? This can also influence the noise behavior.
