ᐅ How can I make BILLY shelves silent?
Created on: 31 May 2019 09:37
Filelis
Filelis
31 May 2019 09:37
Hello everyone, I have some Billy shelves from IKEA in my living room, and I’ve increasingly noticed that the shelves creak and squeak quite noticeably when moved or when loading and unloading them. This is especially annoying when I want to get something from the shelf late in the evening or when children are in the room and we want to keep noise to a minimum.
I’m particularly interested in how to make these BILLY shelves silent without having to take them completely apart. Are there proven methods or materials that effectively reduce the creaking? Which components are especially relevant (e.g., joints, shelves, back panel)? Maybe someone also knows about special lubricants or small construction adjustments that can help.
Thanks in advance for your tips and experiences!
Fitigu
31 May 2019 10:12
Noises from BILLY shelves usually result from friction at wood or metal joints, especially where the shelves connect to the frame and the back panel. To make the shelf silent, I recommend the following steps:
1. Check that all screws and connections are tightened adequately, as loose parts can cause rattling sounds.
2. At the contact points between the shelves and the cabinet, apply thin felt pads or foam strips; these reduce vibrations and friction.
3. An insulating layer can also be placed between the back panel and the side panels, since the thin hardboard back often vibrates significantly.
4. For metal connections (e.g., screws and runners), lightly applying a silicone-based or PTFE-based lubricant can help minimize noise.
I would avoid using WD-40 or other aggressive oils, as these typically do not provide lasting effects on wood and could damage the finish.
V
vin_leo
31 May 2019 11:07
Exactly that! 🙂 I fixed the creaking on my BILLY shelf in a similar way by sticking small felt pads on the edges where wood meets wood. It cushions really well and is almost invisible.
And don’t forget: Screws that sometimes loosen up make the creaking worse. Just tighten them once and then apply a little silicone spray to the metal parts – voilà, quiet shelves! 😉
Ramon4
31 May 2019 12:45
As a supplement and in case additional support is needed: creaking can also occur if the back panel is not properly seated or has slightly warped or loosened over time. Where the back panel slides into the groove of the side panels, it is advisable to apply wood glue sparingly or insert thin strips of felt to prevent noise from occurring.
Another common cause is the slightly fluctuating stability of the shelving unit. Sometimes it helps to secure the shelf to the wall as well, minimizing movement. Especially with BILLY shelves, which are often used freestanding, rattling can be intensified by minor instabilities.
If possible, make sure that the shelves either rest properly or are fixed with the supplied metal pins, as these are also frequent sources of noise.
I hope this clarifies some questions and helps with effective noise reduction!
pikin
1 Jun 2019 08:19
Ramon4 schrieb:
an additional fastening to the wall
This is actually a crucial point, as BILLY shelves can amplify noise due to sideways movements. I would also recommend protecting the shelves with appropriate felt or plastic pads to prevent direct contact with the side panels.
Furthermore, the wall plugs and screws should be regularly checked and tightened if necessary.
For lubrication, a dry PTFE spray is preferable to silicone spray, as it attracts less dust and lasts longer. However, it should be applied sparingly to avoid leaving lubricated spots on the wood.
Far34
1 Jun 2019 12:03
My tip: Stick felt pads to all contact points. Tighten the screws. And attach the shelf to the wall. After that: No more noise. 🙂
