ᐅ How can I make Billy shelves childproof?
Created on: 10 Sep 2024 07:42
dutau
dutau
10 Sep 2024 07:42
I want to make our Billy bookcases in the kids’ room childproof and would like to know which measures you consider recommendable. It’s important to me that the shelves cannot tip over, that there are no sharp edges for small children, and of course, to prevent the risk of children pulling items off the shelves or even tipping the entire unit.
What options are available to childproof a Billy bookcase? Are there specific brackets, safety devices, or materials you use? And what is the best approach if I want to make the shelves more suitable for children, for example?
Thanks for any tips and feel free to share specific recommendations!
Ramon4
10 Sep 2024 09:17
Hello dutau,
very good and important question! Some time ago, I also tried to childproof our Billy shelves – here are my experiences and recommendations:
1. Secure to the wall: This is the most important safety aspect. Otherwise, the shelves can tip over, especially when children try to pull themselves up or lean on them. It is important to use high-quality wall brackets, preferably mounted with anchors and screws of the appropriate size.
2. Protect the edges: IKEA does not offer edge protectors specifically for the Billy shelves, but there are flexible rubber or plastic profiles that can be easily glued on to round off sharp corners. Alternatively, soft edge protectors from baby safety accessories can be used.
3. Closed fronts: When the shelf is open, children can pull things out. You could install acrylic (plexiglass) doors or at least use sturdy boxes or baskets to prevent items from being pulled out.
4. Consider the load: Distribute the weight evenly, placing heavy items at the bottom to improve the stability of the shelf.
5. Securing the shelves: Some people use adhesive pads or small screws to fix the shelves in place to prevent slipping; I would recommend this as well.
If you like, I can also send you links to specific products.
Best regards!
Dilen
11 Sep 2024 13:05
Hello dutau,
to truly make your Billy shelves child-safe, in my view, several steps are needed that work best together:
1. Stability through wall anchoring:
I recommend a double safety measure here – not only using the included brackets but also adapting them to the wall with suitable screws and anchors. It’s important to know whether you have a drywall, concrete, or brick wall, as the anchoring differs depending on that.
2. Additional protections against tipping:
Children can also pull on the shelves from the side. Therefore, in addition to wall anchoring, it makes sense, if possible, to add base plates that act as weights or to install a second wall rail.
3. Corners and edges:
Many underestimate the danger of sharp edges on Billy shelves. Even with smooth surfaces, small children can easily get hurt. Self-adhesive protective profiles made of soft silicone with the appropriate width are highly recommended here. You need to pay close attention to the dimensions of the corners so that the profiles fit precisely and do not come off.
4. Doors and fronts:
If fronts are installed, they should be lockable or childproofed, e.g., with magnetic or child safety locks, so that little ones cannot open the doors and possibly pull out heavy objects or injure themselves on shelf parts.
5. Checking the shelf inserts:
You can additionally screw the shelves in place or fix them with small angle brackets, so they don’t slip or fall out under load.
In conclusion: I’d ask you to briefly describe whether the shelf is placed in a living room with a standard wall or specifically in a children’s room with, perhaps, softer floors, etc., so that I can give you a more accurate assessment.
Best regards!
Ramon4
11 Sep 2024 18:49
Dilen schrieb:
Self-adhesive protective profiles made of soft silicone with the right width are highly recommended here.
I can only confirm that. Additionally, it helps if you regularly check these profiles, as they tend to come loose or shift in places with daily use around children.
Dilen schrieb:
Finally: I would ask you to briefly describe whether the shelf is installed in a living area with standard walls or specifically in a children's room with perhaps softer flooring, so that I can give you a more precise assessment.
That would also be my question for you, dutau, because especially with drywall (plasterboard) walls, it makes a big difference which anchors and fasteners you use.
Ramon4
12 Sep 2024 07:03
dutau schrieb:
Are there specific brackets, protective devices, or materials you use?
Briefly about specific products:
- For wall mounting, I use heavy-duty anchors (100 kg load capacity) and wide metal angle brackets instead of small IKEA-style brackets.
- Edge protection: Amazon offers various baby edge guards; I have had good experiences with transparent silicone profiles.
- For cabinet fronts, I recommend child safety locks with magnetic catches, which are easy to install and remain discreet for small children.
- To secure shelves, I use small metal angles fixed with appropriate screws into the shelving wood.
If you’re interested, I can also share tips on the right tools to use to avoid damage when installing the safety devices.
