I recently assembled my IKEA Billy cabinet, but the doors make quite loud noises when closing, which is especially disturbing at night. I have already tried adjusting the hinges a bit, but the noise level remains high, particularly when the doors hit the cabinet side.
My question is: how can I make the Billy doors close quietly without any squeaking or banging? Are there special dampers, alternative hinges, or perhaps other practical solutions that are easy to implement without having to rebuild the entire cabinet?
I look forward to your tips and experiences!
Hello Rulo63,
I can relate to your situation – the loud slamming of doors is really annoying, especially in quiet environments like at night.
In addition to the rubber bumpers mentioned by pakokla and usron, it can help to lubricate the hinges with a bit of lubricant (e.g., silicone spray or a special furniture oil). This not only prevents squeaking but also reduces wear.
If that isn’t enough, there are also so-called soft-close adapters for IKEA hinges that can be retrofitted. These mechanically cushion the closing, allowing the doors to shut very gently. Installing them takes some effort, but it often pays off in practice.
If you have any questions about installation, I’m happy to help!
V
vinicius4419 Sep 2019 07:39I would proceed as follows today:
1. Check whether the doors and hinges are properly adjusted, ensuring they close flush.
2. Glue impact buffers made of soft materials such as silicone or foam rubber at the contact points.
3. Apply lubricant to the hinges to prevent squeaking.
4. Optional: Retrofit soft-close mechanisms if desired.
This combination usually results in very quiet or noiseless doors. A complete hinge or door replacement is usually not necessary.
Be careful with cheap adhesives: they must not leave marks on the wood.
pakokla schrieb:
You can attach small bumpers made of silicone or rubber to the inside edges of the doors.This is a common suggestion, but it’s not always the best solution. The question is whether the noise actually comes from the hinge mechanism or the door’s fit. Addressing only the symptoms without analyzing the root cause can lead to recurring problems later on.
Have you checked if the doors are aligned properly and if the hinges are securely fastened? Even slight misalignments can increase rattling or banging noises.
If cushioning alone doesn’t help, it’s worth taking a closer look at the structure and adjustment of the cabinet—digging deeper into the issue often leads to better results.
