ᐅ How can I install BILLY shelves in rental apartments without drilling?
Created on: 21 Jun 2024 16:37
teoachmed
teoachmed
21 Jun 2024 16:37
Hello everyone, I have a somewhat specific question: How can I secure BILLY bookshelves, which I would like to place in my rented apartment, without drilling? I understand that drilling is usually the best way to ensure a safe and stable installation, but since I’m renting, I don’t want to make holes in the walls.
Specifically, I’m looking for solutions that will both prevent the shelf from tipping over and stop it from wobbling or shifting during normal use. The walls in my apartment are mostly drywall (plasterboard), sometimes with wallpaper. Are there special mounting kits, clamps, or other techniques that work reliably? I have also considered slim supports that can be tensioned between the floor and ceiling, but I’m unsure how stable that would really be.
I would appreciate concrete advice, experiences, or product suggestions that work well in rental apartments and leave no damage behind. Thanks in advance!
neoren
21 Jun 2024 17:05
You can combine anti-tip safety devices with adhesive tape or adhesive pads to at least prevent tipping over. For drywall, there are special clamp mounts available on the market that do not require drilling. Alternatively, telescopic poles between floor and ceiling provide a stable support for BILLY shelves.
Joshbe
21 Jun 2024 18:42
For the secure attachment of BILLY shelves in rental apartments without drilling, there are several proven methods:
1. Anti-tip safety devices with adhesive pads: These reduce the risk of tipping but are only suitable for light loads.
2. Telescopic poles between floor and ceiling that stabilize the shelf are especially useful for drywall without causing damage from drill holes.
3. Furniture brackets with strong mounting adhesive (e.g., 3M Command Strips) can provide additional stability.
Important: None of these methods replace proper wall mounting, and all have their limitations. Especially with heavy loads or if children are present, I recommend consulting the landlord before use.
teoachmed
22 Jun 2024 08:21
neoren schrieb:
Telescopic poles between floor and ceiling provide a stable support.
That sounds interesting, but how exactly do I attach the shelf to the telescopic pole? Are there special adapters or brackets for that? I imagine the shelf needs to be secured somehow so it doesn’t tilt sideways despite the support.
Joshbe schrieb:
Furniture brackets with mounting adhesive can add extra stability.
Would something like this hold reliably on drywall? Are there specific product examples or practical experiences? My main goal is for the shelf to remain stable under normal use without causing any damage, especially when moving out.
Jensson
22 Jun 2024 11:49
The topic of safely securing BILLY shelves in rental apartments without drilling can be approached effectively with a multi-step method:
1. Stability against tipping: Use a telescopic ceiling support. This works by wedging between the floor and ceiling. There are special screw sleeves or brackets that can be attached to the inside of the shelf. These brackets are then fixed to the support, keeping the shelf stable.
2. Adhesion on drywall (plasterboard): Furniture brackets with strong mounting adhesive can hold but are limited under load and tend to detach with heavier shelves. Products like 3M Command Strips, which are specifically designed for furniture, are recommended. How long they actually hold depends heavily on factors such as room temperature and weight.
3. Alternative: If drilling is completely out of the question and maximum stability is desired, a combination of a telescopic rod plus additional adhesive pads or anti-slip mats under the shelf base is advisable.
Important: Before purchasing, check the maximum load capacity of the adhesive products and the height of your ceilings for the telescopic support. If you have children or pets, some experts strongly recommend drilling without compromise since accidents caused by tipping can result in significant damage.
In summary:
- Telescopic rod plus mounting brackets on the shelf
- Reinforcement with mounting adhesives (e.g., 3M Command)
- Anti-slip mats
If you want, I can gladly provide product names and sources.
