ᐅ How can I customize the finish of Ikea Metod kitchen cabinets with paint?
Created on: 14 Jun 2020 08:37
Eraybo
Eraybo
14 Jun 2020 08:37
Hello everyone, I am planning to customize my Ikea Metod kitchen cabinets by painting them to give a personal touch and move away from the standard look. My specific question is: What steps and materials are recommended to paint the Metod fronts and carcasses without causing damage? I have heard that surface preparation and priming are crucial, but what is the best way to proceed exactly? Are there particular paints that work especially well, and what about durability? Additionally, I am interested in whether doors and drawers should be removed before painting and which tools are most suitable. I look forward to your detailed experiences and advice to avoid any beginner mistakes.
Scarlett
14 Jun 2020 10:22
Hello Eraybo, I think your question is great because painting Ikea Metod cabinets is really a fantastic way to customize the kitchen. I have painted several fronts myself and believe that the first step is to clean the surfaces thoroughly and then lightly sand them with fine sandpaper to help the paint adhere better.
Eraybo schrieb:
Which steps and materials are recommended to paint the Metod fronts and carcasses without causing damage?
Yes, definitely remove the doors and drawers first; this makes the work much easier and allows better access to the surfaces. I used a semi-matte acrylic paint – it’s durable and doesn’t have a very strong smell. For durability, I find it important to apply a primer beforehand, otherwise the paint can peel or look uneven. I know it sounds like a lot of work, but in the end you’ll feel like a pro if everything turns out well. If it gets stressful, don’t get discouraged; any blemishes can be fixed later.
rekijan
14 Jun 2020 11:59
Scarlett schrieb:
I used a semi-matte acrylic lacquer paint – it’s durable and doesn’t have such a strong smell.
Haha, the tip about using paint with less odor is really valuable! 😄 I read that for Metod-style fronts, it’s best to use special spray paints. But isn’t masking everything off a huge hassle?
My advice: Rolling works well if you use a fine foam roller to avoid bubbles. It’s also important to keep the room temperature around 20 degrees Celsius (68 degrees Fahrenheit) so the paint dries better.
Eraybo schrieb:
I’m also curious whether doors and drawers should be removed before painting and which tools are best.
Removing doors is definitely a good idea; otherwise, you’ll end up with ugly drips and areas that are hard to reach. You can take it easy and have fun – it’s a bit like painting!
Bagupo
14 Jun 2020 14:48
Eraybo, remove and sand down. Then apply primer and paint. I recommend acrylic paint or spray can. Allow each coat to dry thoroughly between applications. Tools: foam roller or paintbrush. Avoid high gloss, as it tends to look uneven quickly.
Eraybo
15 Jun 2020 07:15
Thanks for your tips! I still have one question: When sanding the cabinet fronts, I assume it’s essential to use very fine sandpaper (e.g., 240 grit or finer) to avoid scratching the surface, right?
Scarlett schrieb:
I have painted several fronts myself and think the first step should be to clean the surfaces thoroughly and then sand them with fine sandpaper
Also, I’m wondering if it’s advisable to use a special primer for plastics before painting, since Ikea Metod fronts are partly made of coated wood-based panels. I’m worried the paint might not adhere properly otherwise. Which primer would you recommend?
Additionally, I’m interested in how many paint layers are ideal to keep the surface durable without making it too thick and prone to damage.
Scarlett
15 Jun 2020 09:48
Eraybo schrieb:
When I sand the fronts, I assume I should definitely use very fine sandpaper (e.g. 240 grit or finer) to avoid scratching the surface, right?
Absolutely correct. I recommend using 220 to 240 grit; anything coarser than 180 can leave scratches that will be visible in the end. Sanding even finer after priming also helps achieve a smooth surface.
Eraybo schrieb:
whether it makes sense to use a special primer for plastics before painting
Yes, definitely! A plastic adhesion primer or a universal primer ensures that the paint adheres reliably. I use a 2-component primer, which is a bit more expensive but really worth it.
Eraybo schrieb:
how many coats of paint are ideal
Three coats of paint are ideal—allow each coat to dry well and lightly sand between coats if the surface becomes rough. This way, you’ll achieve a durable and even finish.
