ᐅ How can I customize Ikea Pax wardrobes with individually designed doors?
Created on: 2 Jan 2024 18:42
jogarrison
jogarrison
2 Jan 2024 18:42
I am planning to customize my Ikea Pax wardrobes with individually designed doors and am looking for proven methods and tips. Specifically, I am interested in how to completely replace the standard doors or if there are practical options to visually enhance the existing door surfaces—such as with adhesive films, printed fronts, inlaid materials, or custom-made doors. It is also important for me to know which tools and materials are best suited for the project and how to maintain stability and functionality (e.g., hinges) most effectively. Are there common pitfalls or special experiences you could share? Thanks in advance for any helpful advice!
sifope
3 Jan 2024 07:39
jogarrison schrieb:
I am planning to outfit my Ikea Pax wardrobes with custom-designed doors and am looking for proven methods and tips for this.
Interesting question, especially since many people rely on the prefabricated doors for Pax wardrobes. However, I would like to point out that not every custom design is truly compatible with durable quality or ease of installation. For example, if you want to make doors yourself using MDF panels, you should pay particular attention to measurements and material thickness to ensure the doors’ stability and the proper fit and function of the hinges.
jogarrison schrieb:
Are there any common pitfalls or special experiences you could share?
A common stumbling block is the hinges: Ikea uses special cup hinges that cannot be easily replaced with standard hinges. Additionally, the doors often have a bored pattern that matches the cabinet frame. Custom doors therefore either need to match the existing hinge holes or require new holes to be drilled, which is not always easy. Without precise tools, this can quickly become frustrating.
I would recommend carefully analyzing the wardrobe type and hinge system before any custom design, and if necessary, making your own drilling templates.
pikin
3 Jan 2024 09:02
sifope schrieb:
A common stumbling block is the topic of hinges: Ikea uses special drilled fittings that cannot simply be replaced with standard hinges.
I would like to add that Ikea Pax actually has a standardized drilling pattern that can usually be accurately replicated with the supplied hinges. Anyone making custom doors should follow this exact drilling pattern to be able to use the original hinges.
Suitable materials include MDF or particleboard as well as plywood or even joinery boards, depending on the desired appearance and load-bearing capacity. A typical thickness for sturdy doors is between 18 and 22 mm (0.7 and 0.9 inches).
Recommended surface finishes are:
- High-quality foils
- Paint (with appropriate primer)
- Covering with custom-designed vinyl films
- Visible elements such as framed glass or mirrors
Tools: A drill stand for precise drilling, a cordless drill with the right bits, and possibly routing equipment.
Common pitfalls:
- Inaccurate drilling causes gaps or restricts the function of the hinges
- Too lightweight panels can sag on wide doors
- Missing corner profiles for handles
Therefore, I would advise respecting standard dimensions and the original hinge technology when designing your own doors.
angel
4 Jan 2024 11:57
To add some practical advice to the question "How can I customize Ikea Pax wardrobes with individually designed doors?":
There are basically two options:
- Fabricate completely new doors: For this, it’s best to take accurate measurements of the existing doors, replicate the exact hinge dimensions, and possibly create a drilling template. Materials such as MDF or solid wood are suitable. Painting or veneering can be done according to your preference.
- Upgrade existing doors: Instead of using new material, you can work with special adhesive films or magnetic chalkboard sheets. Incorporating mirrors or shelves into the door front is also possible without replacing the entire door.
It’s important to always keep in mind that functionality can be affected by incorrect dimensions or additional weight (e.g., heavy glass panels). If you plan to “cut” new doors yourself, it’s advisable to use professional routing tools or seek help.
If anyone is unsure about installation, I also recommend mounting the supplied hinges on a test piece first to avoid mistakes.
