ᐅ How can I equip IKEA BESTA units with casters?
Created on: 15 May 2019 08:47
Lisgo60
Lisgo60
15 May 2019 08:47
Good morning, everyone!
I have owned an IKEA Besta shelving unit for a while and am considering how to easily add casters to it.
My goal is to make the shelving more mobile without compromising stability or design.
Has anyone had practical experience with this and can offer advice on which casters work well with the IKEA Besta series, the best way to install them, and any special considerations?
I would like to make as few modifications as possible to the furniture itself, preferably using existing drill holes or attaching to the back panel.
I’m also interested in whether certain types of casters (e.g., with brakes, different materials) are particularly useful, especially regarding load capacity and floor type.
Looking forward to your feedback and personal experiences!
Johnathon
15 May 2019 10:23
Hello Lisgo60,
Your question about retrofitting casters on the IKEA BESTA shelving unit is very well asked and indeed requires some planning. First, you should clarify which version of the BESTA unit you have, as there are different combinations with a plinth, feet, or panels.
Most caster base solutions work best if you modify the unit so that the casters are attached directly to the bottom panel or a stable subframe. It is important to pay close attention to the load rating of the casters—many standard casters are designed for a maximum of about 25 to 30 kg (55 to 66 lbs). So if your BESTA unit is fully loaded, this could be problematic.
Here is a step-by-step overview of how to proceed:
- WEIGH THE UNIT: First determine the weight (empty and fully loaded)
- CHOOSE CASTER TYPE: Casters with a high load capacity (at least 40–50 kg (88–110 lbs) per caster) and locks for extra safety
- FIND FIXING POINTS: Ideally at the corners underneath the bottom panel
- INSTALLATION: If possible, use the existing holes for the base attachment or pre-drill (caution: consider material thickness!)
- REINFORCEMENT: For thin bottom panels, consider adding an additional wooden plate as a base
Caster materials are often plastic, rubber, or metal with rubber wheels. For sensitive flooring, soft rubber wheels are recommended.
A final note: since the BESTA is relatively lightweight in construction, using casters can reduce stability somewhat, especially if the casters are lockable and the unit is moved frequently. For regular movement, floor mounts with lockable casters are practical.
Could you provide more details about your specific BESTA model? That would help in offering more precise recommendations.
pautanner
15 May 2019 11:48
Great explanation, Johnathon! I would add that when choosing casters, you should not only consider the load capacity but also the material. Especially if you have hardwood or laminate flooring, casters with a soft rubber coating are definitely worth it – they protect the floor and save your nerves! 😄
Also, remember not to overtighten the screws during assembly, as the wood can easily split. It’s better to go slowly and carefully.
If you feel like it, try testing how heavy the fully loaded BESTA shelf actually gets – people often underestimate that. And one more tip: casters with brakes are very practical if the shelf should stay in one place but still be somewhat movable occasionally.
Looking forward to hearing how it goes for you! 🍀
COLEBAR
15 May 2019 12:07
If you want casters for the IKEA BESTA, use furniture casters with through holes or shaft screws.
Screw them to the underside, preferably on the bottom panel.
Always use locking casters, otherwise the shelf will move when you don’t want it to.
Jeanbar
16 May 2019 09:12
Lisgo60 schrieb:
I want to make as few changes as possible to the furniture itself, preferably a solution using the existing drill holes or by attaching to the back panel.
Hello Lisgo60,
Your caution about making minimal changes to the furniture is completely understandable. If you want to preserve the original structure, I recommend considering furniture casters with adhesive plates. These stick to the floor without any drilling, but they usually have a lower weight capacity.
Alternatively, you could consider a mobile base platform: attach your BESTA shelf to a sturdy wooden board fitted with casters. This has the advantage of leaving the furniture itself untouched while making it mobile. The board should be stable and not too thick to prevent the shelf from wobbling.
However, in general, the BESTA system is designed more for stationary use, so directly mounting casters might affect its stability.
Have you checked how much weight you plan to move? This will greatly help in choosing the right casters.
Good luck with your project!
