ᐅ How can I easily modify IKEA Metod cabinets during renovations?
Created on: 10 Jul 2018 08:37
avditanHello everyone,
I am currently planning a kitchen renovation involving IKEA Metod cabinets and am looking for practical ways to adapt these cabinets to new conditions as easily and efficiently as possible. Specifically, I am interested in how to adjust measurements when wall distances change or when individual modules need to be removed or added, without too much effort in disassembling or recalibrating the cabinets.
Are there any special tricks or modular add-ons that work well if you don’t want to fully replace the cabinets during a renovation but rather want to smartly modify existing systems? I am especially interested in how to handle adjustments for unusual room layouts or built-in appliances to take full advantage of the Metod system’s flexibility.
I look forward to your experiences, tips, or recommendations for useful accessories or supplementary materials that make sense in such situations!
Hey avditan,
I completely understand your wish for easy adjustments with IKEA Metod – especially during renovations, you want to avoid as much hassle with the cabinets as possible. 😊
A few things I learned during my renovation:
- IKEA offers flexible dividers and side panels as extension sets that make it easy to close gaps or customize.
- If you need to change dimensions, try edge strips or moldings, which are affordable, easy to adjust, and can be glued on – they also add visual stability.
- For uneven walls or if something is off-level: adjustable feet under cabinets help level everything so it stands straight and secure.
- And if you want to change the interior layout, like adding more drawers or pull-out shelves – Metod is very modular and works great for that!
Enjoy your renovation, you’ve got this!
Hello avditan,
I would like to organize my response to give you practical advice on how to easily adapt Metod cabinets during renovations:
1. Measure and plan:
- Measure your new room dimensions precisely, especially widths and heights.
- Consider uneven walls and door swings so you can incorporate them into your plan.
2. Modify modules:
- Metod is made of standardized components—you can replace or omit individual cabinets without compromising the entire system.
- For irregular walls: trim side panels or back panels using fine tools, but be careful to maintain stability.
3. Fastening and stability:
- Use the supplied connecting fittings to securely join cabinets together.
- Many users also use angle brackets to fix cabinets to walls or floors.
4. Keep interior fittings flexible:
- Metod’s adjustable interior fittings allow you to customize, add, or reposition drawers and shelves as needed.
A common mistake is cutting too early or not providing enough stability—better to measure twice and then cut.
If you want more technical details or examples, just let me know!
2. Modify modules:
Hello avditan,
I would like to address your concerns in more detail, as renovations often require more specific adjustments.
With the IKEA Metod system, the greatest flexibility comes from the standardized dimensions (for example, 60 cm (24 inches) width and 80 cm (31 inches) height per module), which keep the system easy to combine. However, when deviations occur, there are several options available, particularly:
- Cutting side panels and back panels: Use fine circular saw blades to achieve clean and straight cuts. Make sure not to damage any load-bearing parts.
- Using filler strips: These narrow wood or plastic strips help when there are small gaps between the cabinet and the wall. This allows you to fit the cabinet easily without major alterations.
- Adjusting baseboards and trim: These can be cut to size or even mounted flexibly with additional corner brackets.
- Height adjustment: Use adjustable feet or modify the base height to compensate for uneven floors.
A frequently overlooked challenge is stability when removing modules. The remaining cabinets sometimes need extra fastenings to the wall or floor to prevent twisting.
To better understand your needs: What exactly are your requirements? Do you want to change fixed dimensions or move modules? And what kind of space do you have—is it a corner, a recess, or an open area? These details significantly influence which measures are appropriate.
I look forward to hearing more!
PLOMA schrieb:
For better understanding: What exactly are your requirements? Do you want to change fixed dimensions or move modules?Wait for the answer first.
Briefly beforehand: Use adjustable feet and filler strips. If it becomes too uneven, cut off and re-plan.
