arnelna6514 Apr 2024 13:27Hello everyone,
I am considering how to customize the color of my Ikea Pax wardrobe to better match my room design. The standard colors from Ikea don’t fully appeal to me, so I would like to learn about ways to visually enhance or modify the wardrobe without limiting its functionality or making it difficult to reverse the changes.
I’m especially interested in tips on coloring techniques like painting or applying adhesive films, which materials work best for these methods, and whether there are alternative design ideas such as stickers, vinyl wraps, or even creative handles and front panels. It is important to me to know what preparation the wardrobe requires, what to pay attention to when painting, and how durable such changes usually are.
Are there any experiences with combinations, for example, coloring only certain parts of the wardrobe or how to create clean transitions between different colors?
I look forward to your tips, experiences, and recommendations on the topic “How can I customize the color of the Ikea Pax wardrobe?”
Thank you in advance!
arnelna65 schrieb:
I’m thinking about how to customize the color of my Ikea Pax wardrobe to better match my room’s design.Hey, you put that perfectly – it’s exactly what many of us think when we see the plain Pax models! 😄 In my opinion, painting and applying adhesive films are the classic ways to bring your wardrobe to life. If you go for painting, make sure to use the right paint for MDF or particleboard – spray paint works best for a very smooth finish.
Adhesive films are easy to apply and removable, ideal for those who like to change things up now and then. If you want something special, try patterned films or even a mix of matte and glossy finishes – a real eye-catcher!
My tip: divide the wardrobe into separate sections (for example, doors vs. side panels) and play with colors – for instance, use a base color for the outer parts and an accent shade for the doors. This way, the wardrobe won’t look too bulky but still gains personality.
And yes, swapping or updating the handles also counts as part of the color design! A bit of metallic paint or colorful knobs can make a big difference without repainting the entire wardrobe. Good luck! 🍀
arnelna65 schrieb:
especially tips on painting or applying films, and which materials are best suited for thisFor customizing the color of the Ikea Pax wardrobe, I recommend the following approach:
- Preparation: First, thoroughly clean all surfaces and lightly sand them (grit 120-150) to ensure good adhesion of paint or films.
- Painting: Use low-solvent acrylic paint or spray paint designed for wood materials. Priming is advisable if the surface is very smooth.
- Applying films: Self-adhesive PVC films are easy to work with; matte or photorealistic finishes are preferred to achieve a high-quality appearance.
Regarding durability: Painted surfaces tend to be more scratch-resistant than films, but films allow for quicker color changes.
Combining individual colored fronts with neutral sides is common; here, careful masking with painter’s tape ensures sharp color edges. When using multiple colors, plan the order of application and allow sufficient drying times.
Pay attention to material compatibility, as some solvents may damage particleboard. Testing in a hidden area is recommended.
Concerning handles: Replaceable handles offer an easy way to change the look without permanent alterations to the surface.
andre3 schrieb:
Testing in a hidden spot is recommended.Absolutely, I often underestimate that too, and only after painting do I remember that I should have tested beforehand. 😅
A little extra tip, just for fun but with a purpose: if you want something truly personal when wrapping or painting, you can use stencils or stamps to apply patterns.
For example: an abstract line pattern on the door edges that adds a bit of contrast—a kind of “style upgrade” for the standard Pax. This works well with spray paint and doesn’t just look like “plain color.”
And if something goes wrong? Hey, life is too short—just paint over it or rewrap! 😉
A little fun addition: “Whoever makes the Pax colorful, has fun with the paint!”
