ᐅ How can I customize IKEA PAX wardrobe doors with glass inserts?
Created on: 13 Nov 2021 09:43
Timur61
Timur61
13 Nov 2021 09:43
Hello everyone, I am planning to customize my Ikea Pax wardrobe doors with glass panels and am looking for practical ideas and instructions. Specifically, I want to know how I can creatively alter the existing glass panels without completely replacing the doors, to give the wardrobe a more personal look. For example, I am interested in whether it is advisable to apply stickers, paint, or perhaps use films—of course considering the durability and appearance. Which materials and techniques work best for this? Do you have any tips on how to modify the glass panels as easily and cleanly as possible, without compromising the finish or functionality? Thanks in advance for any advice!
bapar
13 Nov 2021 10:02
Hello Timur61, your project is interesting, and there are indeed several ways to customize PAX doors with glass inserts. In general, you should be careful when working with the glass, as it is usually tempered or at least fairly delicate.
- A popular method is applying self-adhesive films, such as frosted glass film or patterned films. These films can be removed without residue and create a pleasant light effect. It is important to apply the film carefully and without bubbles, ideally using a squeegee and on clean glass.
- Alternatively, you can use glass paints applied with a brush or spray technique. These offer a very individual look, but removing them later can be difficult and may not be completely residue-free.
- Some also use sandblasting vinyl films (sandblast-patterned vinyl), which are applied like regular films but create a more matte appearance.
Important: Do not remove the glass panels if you are unsure about handling the material, as it is easy to damage the mounts or glass edges. If you want to remove the panels, first check how they are fixed (usually with insertion strips or clips).
Feel free to say whether you prefer films or are leaning more towards painting, and I can give you more tips on specific products and application steps.
reoleon47
13 Nov 2021 10:41
Hey Timur61, that sounds like a really exciting project! I covered my PAX glass doors with colorful patterned frosted window films – it turned out looking really cool and was super easy to do! The films come in countless designs, which makes choosing them a lot of fun. 🙂
My tip: buy a little extra film in case you make mistakes during application, because peeling and reapplying doesn’t work perfectly. The best results come from using a squeegee and a perfectly smooth surface – it’s best to do this with a helper.
I would advise against painting, as it makes changes more difficult later on, whereas films are quite durable and also easy to remove.
Don’t get discouraged by small bubbles. Just gently lift the film and smooth it out bubble-free with the squeegee. Good luck, it’s going to look great!
Rodolfo
13 Nov 2021 11:15
In summary, there are three main methods to customize PAX doors with glass inserts:
- Applying patterned or frosted window film: the most flexible and reversible option.
- Painting with special glass paint: more permanent but harder to remove.
- Replacing or installing your own decorative glass panels: more effort and higher costs.
Technically, I recommend thoroughly cleaning the glass surface with a suitable glass cleaner (free of silicones or oils) before working on it, to achieve the best results with films or paints. Mounting areas should be well preserved, as these parts are often secured by pressure or clips.
If you choose the film solution, PVC or polyester films with UV protection are advisable to prevent fading. Epoxy- or acrylic-based paints are suitable but should be applied in several thin layers.
The most practical approach is to carefully remove the glass inserts if possible and work on them separately to avoid damaging the doors. Most IKEA PAX glass inserts are secured on one side only, which allows disassembly with careful handling.
A final recommendation: let the doors cure at room temperature for a few days after customization before exposing them to moisture, to ensure durability.
Mekau
13 Nov 2021 11:47
For me, sticking the film is the best solution. Simple, cost-effective, and removable without residue.
Before applying the film, clean the glass thoroughly and use a squeegee to avoid bubbles.
Keatondra
13 Nov 2021 12:05
Hello Timur61, I can confirm the opinion about self-adhesive films. Especially if you are new to projects like this, films are easy to handle and tolerate minor mistakes. Also keep in mind that some films are slightly translucent – ideal if you want diffused light through the doors.
If you prefer a more natural look, you could also use glass paint. This allows for more complex patterns. However, pay special attention to the curing time and compatibility with the glass surface. Some paints are sensitive to scratches.
A final option would be printed patterns on clear acrylic glass, which can be cut to size, but this is more expensive and complex.
Knowing which effect is most important to you would be helpful. Do you prefer patterns, color, or texture?
