ᐅ How can I apply adhesive film to Ikea Pax doors?
Created on: 12 Mar 2016 09:37
Bardiar
Bardiar
12 Mar 2016 09:37
Hello everyone, I recently bought a Pax wardrobe from Ikea and would like to customize the doors by applying adhesive films. I have a few questions: What type of film is best suited to ensure long-lasting durability and good workability? Are there any specific surface preparations that should be done to guarantee proper adhesion and to prevent bubbling or peeling after a few weeks? Additionally, I am interested in any tips for optimal application, such as cutting, applying without air bubbles, and the best way to handle existing handles or fittings when covering the doors. I would appreciate any advice, as I want to achieve a professional result and avoid common mistakes.
Josan
12 Mar 2016 10:14
Hello Bardiar,
I think your question is very well thought out and important, especially when working with films: preparation is everything.
First, I would say that matte or glossy vinyl films are suitable because they are relatively durable and easy to work with. For the surface, you should ensure the doors are grease-free, clean, and dry. It’s best to clean them with a mild detergent and then wipe them down with ethanol or isopropanol – this provides a smooth, adhesive surface.
When applying the film, it’s advisable to roughly cut it first, leaving a few millimeters (inches) of excess to allow for fine adjustments after application. If handles are already installed, it often makes sense to remove them and reinstall later, as this makes the work easier and prevents wrinkles around the edges.
For application, you can use a spray bottle with water and a few drops of dish soap (so-called adhesive solution) to initially position the film on the door. Then, use a squeegee to press out air bubbles from the center toward the edges.
I hope this helps you for now! If you like, I can also post a step-by-step guide.
benonon
12 Mar 2016 11:05
Hello Bardiar,
Your question is quite broad, so I would like to examine the topic in more detail and also include some technical aspects that might help avoid common mistakes.
First of all: Ikea Pax doors have a melamine-coated surface, which can vary slightly depending on the series (smooth, textured, or matte). This melamine coating is generally not very porous, meaning that adhesion for self-adhesive films is not always ideal. Therefore, thorough cleaning is essential. It is best to use a grease-dissolving cleaner, then wipe with isopropanol or denatured alcohol to remove all residues.
About the film itself: There are special furniture films called “cast vinyl films” with a high plasticizer content, which adapt well to flat and slightly curved surfaces. These films have a matte or satin finish that looks elegant and is relatively scratch-resistant. Thickness is important: 80–100 micrometers (0.003–0.004 inches) is optimal.
Preparation:
- Remove the doors and place them on a flat working surface.
- Remove handles, as they complicate the application process and can cause uneven edges.
Application:
- Roughly cut the film with about a 3cm (1¼ inch) overlap all around.
- Keep the working surface, film, and air as dust-free as possible.
- Lightly spray the adhesive solution (water with a drop of dish soap) so the film can be repositioned.
- Use a squeegee (preferably felt or plastic to avoid surface damage) to work from the center towards the edges, pushing out air bubbles.
At the edges: If the door has a rounded or milled frame, as many Pax doors do, it may be necessary to gently warm and stretch the film at the edges with a heat gun. Please be very careful here to avoid bubbles or unsightly wrinkles.
Drying and curing:
Allow the doors to dry thoroughly for about 24 hours before reinstalling or putting any stress on them. Avoid heat and moisture during this time.
Feel free to describe your doors in more detail—whether they are smooth or framed—and if you already have certain films in mind? Then I could give you more targeted advice.
lubla
12 Mar 2016 14:22
Clean the doors thoroughly and unscrew the handles. Cut the film with a slight overlap, apply it wet (water + dish soap), and smooth it out from the center to the edges using a squeegee. If the edges are rounded, carefully warm and adjust them.
benonon
13 Mar 2016 08:47
Josan schrieb:
It’s best to clean with a mild detergent and then wipe down with spirits or isopropanol – this creates as smooth and adhesive a surface as possible.
This is an important point, without which the film can quickly develop bubbles or peel off.
Josan schrieb:
If handles are already installed, it often makes sense to remove them and refit them later; this makes the work easier and prevents wrinkles at the edges.
Exactly, that is what I would strongly recommend. People often underestimate how difficult it can be to apply film around handles.
Another interesting point is that some users swear by films with air-release technology because this almost completely prevents bubbles during the adhesion process.
So my tip is: Don’t skimp on the material, buy the right film, use good adhesive fluid, clean the surface, and remove the handles.
Do you have any special doors that are more frame-style or flat?
barge
14 Mar 2016 10:59
Hello Bardiar,
I just wanted to quickly add something: I covered my Pax doors with self-adhesive vinyl film, and it worked out well. Important: Take your time and, above all, enjoy the process!
- Clean the surface thoroughly, otherwise you’ll get nasty bubbles.
- Wear gloves; fingerprints are really annoying.
- You can buy a squeegee cheaply at hardware stores; definitely get one, it makes all the difference.
- If the film is slightly crooked, don’t worry – you can peel it off again and reposition it using a spray solution.
And remember: It doesn’t have to be perfect; often it looks cozier when you can tell it’s handmade. Good luck!
