ᐅ How can I convert a large Pax wardrobe into a walk-in closet?
Created on: 11 Nov 2022 08:47
lepasinHello everyone,
I am planning to convert my large IKEA Pax wardrobe into a walk-in closet. Currently, the Pax stands as a traditional wardrobe with doors and drawers against the wall, but I want to make better use of the space behind it and create more storage. Specifically, I am considering removing the back panel and possibly modifying the sides or doors to create something like a walk-in closet with shelves and clothes rails.
Has anyone had experience with this kind of conversion? What technical aspects should I keep in mind to ensure the wardrobe remains stable? Which materials or solutions do you recommend if I remove the back panel? And are there any tips on how to best plan the interior, for example regarding lighting or fittings?
I look forward to your suggestions and shared experiences!
cassandra11 Nov 2022 10:35BELLA34 schrieb:
Removing the back panel is possible, but you should reinforce the sides to keep the cabinet stable.Stability is indeed critical when the back panel is missing, as it significantly contributes to the torsional rigidity. One option is to install additional metal brackets at the corners and wooden braces between the side panels. Anchoring the cabinet to the wall can also be helpful if you don’t intend to use it fully freestanding.
I also recommend using LED strips for lighting installation, as they produce little heat and save space. For the interior, flexible clothing rods and height-adjustable shelving systems, such as those from the Pax accessory range, work well.
Please plan the access before remodeling: Will the cabinet be wide enough to include a door, or will it remain open? You should definitely consider access and ergonomics when designing the space.
I went through a similar renovation. It’s important not to completely remove the back panel, but rather to create an opening for the entrance and keep the rest as a stability support.
In short, always reinforce the corner joints with metal brackets; this makes a big difference. If you want to use the wardrobe freestanding, it’s also advisable to cover the outer sides, otherwise they might warp.
Lighting: LEDs with motion sensors are very practical in walk-in closets – so you don’t have to look for the light switch.
Also, plan enough clearance inside, at least 70 cm (28 inches) wide for comfortable movement.
lepasin schrieb:
Has anyone had experience with a renovation like this? What technical aspects should I consider to keep the wardrobe stable?
edisondan13 Nov 2022 11:59Takutau schrieb:
It is important not to remove the entire back panel, but instead to create, for example, only an opening for the entrance and leave the rest as a stability support.I completely agree with this. Additionally, it is advisable to address stability issues by adding extra cross braces on the back. Alternatively, you can install a thin plywood panel that provides rigidity across the surface without taking up much space.
For the interior, I recommend modular systems to keep your use flexible. Also, make sure there is sufficient ventilation to prevent moisture buildup inside the cabinet, especially if clothing will be stored there for extended periods.
edisondan schrieb:
For the interior, I recommend modular systems so you stay flexible in use.This is an important point. Additionally, when remodeling large pax wardrobes, you should pay attention to the weight. The more compartments and drawers you install, the stronger the brackets and drawer slides need to be.
For walk-in closets, a combination of hanging rods at different heights and open shelves for shoes and accessories is ideal. You can theoretically remove the doors to create a more open space, but the room will then need a door or another closing system to prevent dust from coming in.
If applicable, installing a small seat or a surface for dressing may also be worthwhile.
