ᐅ How can I extend Ikea PAX wardrobes to store electronic devices?
Created on: 16 Aug 2020 10:23
karfoHello everyone, I am currently facing the challenge of customizing my Ikea Pax wardrobes to securely and neatly store various electronic devices. Specifically, I am looking for suitable interior fittings, special modules, or clever inserts that ensure good air circulation to prevent overheating, while also allowing adequate cable management. Maybe someone has experience or tips on how to accommodate devices like routers, gaming consoles, or small stereo systems inside Pax wardrobes without running into space issues or heat-related failures. I would appreciate detailed advice and possibly shared experiences with certain complementary products or DIY solutions.
I would recommend installing special ventilation grilles to improve air circulation. Additionally, plastic or rubber cable grommets help to route cables neatly and prevent damage. Adjustable shelves or universal brackets can be purchased separately at hardware stores or IKEA and customized as needed.
Leonardteo16 Aug 2020 14:39Karfo, your question about storing equipment in Ikea PAX wardrobes is well formulated and addresses the key points to consider with such furniture: ventilation and cable management. For ventilation, I recommend installing ventilation grilles in the back panels or alternatively using a perforated back panel. This ensures air circulation, which prevents overheating. For cable management, self-adhesive cable channels inside the sides of the wardrobe are ideal. Additionally, you can install power strips with rocker switches on the bottom or side of the wardrobe to control devices individually. For the shelves, glass shelves are especially suitable, as they retain less heat from below and look elegant. Finally, there are also pull-out boxes with fans, but these increase power consumption. Ultimately, the goal is a combination of mechanical ventilation and effective cable organization. I hope this helps you.
Hello karfo, I find your precise question very helpful for everyone dealing with the technical use of furniture. In addition to the points already mentioned, I would like to highlight that besides ventilation, moisture control also plays an important role, especially in tightly closed PAX cabinets. Therefore, use desiccant granules or small dehumidifiers to prevent damage to the equipment. It is also advisable to make adjustments so that devices remain easily accessible, especially if you need to regularly change or connect most of the technical devices. For cable management, flexible spiral tubing or textile tape help to keep cable bundles neatly together. Some users install small LED strips with switches, so the equipment remains clearly visible without having to open the entire cabinet. If you want to build it yourself, I also recommend paying attention not only to visual aesthetics but also to stability and safety when mounting the equipment. In general, PAX cabinets can be repurposed very well as long as you consciously consider the technical requirements. I would suggest making a sketch first and possibly testing individual components separately before permanently mounting everything.
