ᐅ How can I childproof and lock Ikea BESTA furniture?
Created on: 9 Jul 2021 08:34
eriksenmau
eriksenmau
9 Jul 2021 08:34
Hello everyone, I recently bought some Ikea Besta furniture and I’m wondering how to childproof it as effectively as possible. These units are originally designed for living rooms or home offices, but since there are small children in our home, I want to prevent them from playing with drawers and doors, potentially hurting themselves or taking items they shouldn’t.
I’m looking for a solution that isn’t too complicated, works without major modifications, and doesn’t stand out too much visually. Are there any proven mechanisms, special locks, or tricks you can recommend to childproof this furniture? I would appreciate tips, product suggestions, or information on the pros and cons of different methods.
enrique7
9 Jul 2021 10:15
eriksenmau schrieb:
I am looking for a solution that is not too complicated, works without major renovations, and is not too noticeable visually.
This is an important limitation, as many security solutions do not meet these criteria. You should consider whether you prefer semi-custom locks that are relatively discreet, or a general locking system—such as a plug mechanism that secures all doors at once.
Also, how mobile are the children? This greatly affects how durable the solution needs to be. Some simple clip or latch holders provide only psychological protection and can be easily bypassed by older children. Have you already tried products like these safety latches or cabinet locks? There are also magnetic solutions that are mounted inside the door and can be opened from outside using a special key.
klo40
9 Jul 2021 11:58
As a supplement to the explanations: Ikea BESTA furniture is modular and often equipped with simple doors and drawers, which can be fitted with some common child safety locks quite easily. The methods differ in terms of installation:
- Clamp mechanisms: Installed without screws, simply clipped onto the door frame. Advantage: no damage to the furniture; disadvantage: they can come loose or children may sometimes test and remove them.
- Screw-mounted locks: Provide stronger hold and more security but can damage the furniture surface.
- Magnetic locks: Installed on the inside; a magnetic key, which children do not have, is needed to open from the outside. Advantage: barely visible; disadvantage: somewhat more expensive and installation requires countersinking the magnets.
In most cases, I recommend magnetic locks because they are aesthetically pleasing and function very securely when installed correctly. It is important to take exact measurements before installation to avoid mistakes, as the drilling needs to be precise.
Blavin
9 Jul 2021 14:22
I agree with the previous points but would like to add some comments regarding the stability and durability of such locks. For small children who might crawl on the floor with a child seat or pull on doors with force, simple plastic snap locks are often not sufficient.
My recommendation is based on the following points:
- Use metal cabinet locks or lockable latches that are not easy to open.
- Special magnetic systems work well if children do not have access to the magnetic key required to open them.
- Additionally, installation should be carried out professionally, since inaccurately mounted locks can impair their function.
It is also important to consider the material properties of the BESTA furniture – the surfaces are often coated and less resistant to stronger mechanical fastenings.
Espen
9 Jul 2021 16:03
I use magnetic child safety locks for my Besta furniture. These are installed on the inside. To open from the outside, a magnetic key is required, so children cannot access them. They are easy to install and work reliably.
eriksenmau
10 Jul 2021 09:44
enrique7 schrieb:
You should consider whether you prefer investing in semi-custom locks that are relatively discreet, or if you want a general locking mechanism – for example, a latch system
That's a good point. For me, it’s important that the solution is not only secure but also practical for everyday use. A general lock or a large bolt might be effective, but it would quickly become annoying with daily use.
klo40 schrieb:
In most cases, I recommend magnetic locks because they are aesthetically pleasing and work very securely when installed correctly.
Magnetic locks sound reasonable, although the installation might be a bit tricky. Does anyone have experience with whether these can be installed on BESTA furniture without major modifications? I want to avoid visible holes or drill marks as much as possible since the furniture is new.
