ᐅ How can I carry out necessary repairs on IKEA Platsa furniture myself?
Created on: 10 Mar 2015 18:37
gubula
gubula
10 Mar 2015 18:37
Hello everyone, I have a large Platsa shelving system from IKEA that, after some time of use, unfortunately has developed a few minor damages and defects that I would like to repair myself. Specifically, I am dealing with loose hinges, chipped edges, and loose back panels, which make the furniture appear unstable overall.
My question is: How can I properly carry out these necessary repairs on IKEA Platsa furniture by myself? What materials and tools should I ideally use, and are there any special tips or tricks to ensure the stability and appearance are restored? Are there any issues that might be better left to a professional?
Thank you in advance for your advice!
jakob70
10 Mar 2015 18:44
It’s best to start by loosening the hinges, then check the screws and replace them if necessary. For chipped edges, wood glue and small clamps work well. You can usually secure back panels with small nails or staples. Tools needed: screwdriver, hammer, wood glue, and possibly clamps.
flota
11 Mar 2015 09:16
jakob70 schrieb:
Best to loosen the hinges first, then check the screws and replace them if necessary.
That’s a good start. I recommend paying close attention to the specific joining fittings used in Platsa furniture. Since Platsa often involves nails and particleboard, I suggest using fine wood filler on chipped edges to smooth out any imperfections before painting or sanding.
Also, it helps to fit the back panels precisely, as they contribute significantly to stability. If they come loose, reinforce them with small nails. If screws no longer hold, fill the holes with wood shavings mixed with wood glue, let it cure, and then re-screw.
For more severe damage, such as structural breaks in the carcass, I would advise against DIY repairs and recommend seeking professional assistance instead.
Teonon
12 Mar 2015 07:22
Oh, that sounds totally doable! 🙂 I once had a cabinet with minor damage myself and managed to fix it using a few simple tricks. My advice: Set aside a calm afternoon, get some good wood glue from the hardware store, clamps to hold everything in place, and maybe a few extra small screws just in case!
The most important thing is not to rush, align the parts carefully, and let everything dry properly. I also had some chipped edges, and I used filler putty for that, then smoothed everything out with fine sandpaper. The result was really impressive!
And honestly: It’s also fun to restore a piece of furniture like that, which gives a great feeling. If you’re having trouble with the hinges, take them off and clean the fittings; that often makes a big difference in how smoothly they open and close.
Good luck, you can do it!
