Hello everyone, I am planning to build an Ikea Metod kitchen unit myself because I cannot fully customize the standard kitchens to my preferences and would prefer to do it myself. My question is: What is the best approach if I want to assemble the individual modules myself? It would be helpful to know which tools and materials are absolutely necessary, how to securely mount the individual carcasses, and if there are any special tips for fitting the fronts and drawers so that everything fits precisely and lasts long-term. Are there any additional reinforcements or modular solutions you would recommend when building a unit like this completely on your own? I already have some DIY experience but want to proceed as systematically as possible—so I would also appreciate advice on a sensible step-by-step assembly process or planning phases. Thank you in advance!
For assembly, you only need a cordless drill, a Phillips screwdriver, and a spirit level.
Make sure to carefully assemble the Metod carcasses using the supplied fasteners. Attach the fronts last to allow for precise alignment.
If you want to increase stability, many people add additional corner brackets at the inner corners for good support.
nodilis schrieb:
How should I best proceed if I want to assemble the individual modules separately? It’s important for me to know which tools and materials I absolutely need, how to mount the carcasses securely, and if there are any special tips for installing the fronts and drawers so that everything fits precisely and lasts in the long term.This is a very good and detailed question that covers the essential points for the DIY assembly of the Ikea Metod kitchen unit. I would recommend starting by planning the entire kitchen unit on paper or digitally using the Ikea dimensions to estimate how the modules best fit together.
Regarding tools: a good cordless drill with adjustable torque, an angled screwdriver or a bit set, and definitely a precise spirit level and a reliable tape measure are important.
For the carcasses, you should use the original connectors as they ensure stability. There are also optional metal brackets you can install at particularly stressed points, for example at the edges where the modules meet. When fitting the fronts, I also advise carefully adjusting the hinges to avoid tension that could cause warping over time.
Another tip: take your time assembling the drawers, as the runners must be installed exactly parallel. The drawer soft-close systems also deserve attention during installation, as there are often slight differences depending on the model.
Finally, I recommend doing small trial assemblies of individual modules beforehand to get a better understanding of the process before screwing all parts together permanently.
I would be interested to know the dimensions of your kitchen unit and whether you are considering special features like corner solutions or recessed countertops?
TEBILO schrieb:
I’m curious about the dimensions you plan for your kitchen island and whether you’re considering special features like corner solutions or built-in countertops?I think it’s great that you’re thinking through the details so carefully—that makes the project much more enjoyable. It can be really frustrating when you’ve already assembled the kitchen island and then realize that things don’t fit properly or you lack stability in key areas.
I’ve also tried connecting Metod cabinets myself and struggled with built-in countertops that didn’t fit perfectly. Since the precision of fit is often not 100%, it makes sense to work with test pieces beforehand and pay attention to the adjustable feet and hinges.
I’d also recommend not being too hard on yourself if something doesn’t go perfectly the first time. Large DIY projects like this require patience and sometimes creative on-site adjustments. Good luck with your build, and feel free to share your experiences!
