ᐅ How can I adjust the Ikea Metod kitchen system to fit the size of my kitchen?
Created on: 2 Jan 2024 10:22
pravaheHello everyone,
I am currently facing the challenge of customizing my IKEA METOD kitchen to fit my rather unusual kitchen dimensions and wanted to ask how you usually handle this kind of situation. Specifically, my kitchen is just over 3.4 meters (11 feet) long, but the room shape is not rectangular; it’s more L-shaped with small niches and walls that aren’t completely even. The typical METOD standard sizes don’t fit perfectly here.
I’m interested in how you approach planning when you need to adjust the METOD modules to a non-standard room layout. Do you use any special tricks, adjustment options, cutouts, or purchase additional parts to compensate for irregularities? Are there tips on which cabinets or panels are best to use to bridge small gaps without having to trim everything?
Also, I want to optimally coordinate the combination of tall cabinets and base cabinets so that no awkward gaps appear in corners and the doors open smoothly.
I look forward to your experiences and advice on the topic “How can I adapt IKEA METOD to fit my kitchen size?”. Ideally, please share practical planning steps and possible pitfalls. Thanks in advance!
Matthewt482 Jan 2024 13:47pravahe schrieb:
I'm interested in how you approach planning when you want to fit the METOD modules to a room that is not exactly standard in size.This is a really good and often underrated question. It’s easy to forget that the METOD kitchen units come in fixed grid sizes, mostly in 20 cm (8 inches) width increments. Here are some tips from me:
- Measure your space as accurately as possible and take any wall irregularities into account.
- Use IKEA’s kitchen planner software to get a feel for the layout.
- Use baseboards and filler strips to compensate for small gaps. IKEA offers various cover and trim profiles for this purpose.
- If you have a recess, you can make targeted customizations or adjustments, such as cutting panels to size or leveling cabinets with adjustable feet.
- Tall cabinets are often more flexible to adjust than base cabinets, since base cabinets are usually fixed to the floor.
pravahe schrieb:
I’d also like to optimally coordinate the combination of tall cabinets and base cabinets, so that there aren’t awkward gaps in corners and the doors open smoothly.Careful planning is worth it here because METOD modules are typically 60 cm (24 inches) wide. Techniques like angled panels at corners or corner cabinets can reduce gaps. There are also special hinges available for doors to make them easier to use in tight spaces.
pravahe schrieb:
My kitchen is just over 3.4 meters (11 feet) long, but the room shape is not rectangular; it’s more L-shaped with small recesses and slightly uneven walls.This naturally makes planning more complex, but with some care, it can be managed very well. Here is a detailed guide on how to adapt the IKEA METOD kitchen to fit your room conditions:
- Step 1: Accurate Measuring
Measure your space down to the millimeter, including the recesses and irregularities in the walls. It’s best to use a spirit level or a laser distance meter. This is crucial to avoid unpleasant surprises later on.
- Step 2: Analyze and Use the Room Shape
For an L-shaped kitchen, divide the area into two zones. Small recesses sometimes can be covered with filler panels or special corner solutions—here you should carefully plan where the room layout tolerance is acceptable.
- Step 3: Understand METOD Module Sizes
METOD uses a 20-cm (8-inch) grid—cabinets typically come in widths such as 20, 40, 60, or 80 cm (8, 16, 24, or 32 inches). This can make it challenging to fit your exact dimensions. Ideally, plan your kitchen layout in modules that leave minimal leftover gaps at the end.
- Step 4: Compensate with Fillers and Cover Panels
For the inevitable small gaps, there are fillers and cover panels that you can cut to size. Make sure their color and material match the rest of the kitchen for a visually coherent look.
- Step 5: Adjust for Uneven Walls
Use adjustable feet under base cabinets to compensate for uneven floors or walls. For tall cabinets, sometimes trimming the back panel slightly or using spacers can help.
- Step 6: Use Corner Solutions Effectively
Especially in L-shaped kitchens, corner cabinets with carousel or pull-out solutions help maximize space. However, avoid corner cabinets that are too narrow as they may limit functionality.
- Step 7: Consider Doors and Opening Angles
Check carefully how cabinet doors open—especially in corners. There are special hinges to facilitate opening or corner solutions where doors are offset.
If you want, I can also assist you in specifying your measurements and help with planning. The combination of technical, craft, and design aspects makes it interesting, but it requires a step-by-step approach.
To assist you more precisely: What are the exact dimensions of your L-shape? Where exactly are the uneven walls? Then we can consider together which cabinet types and special solutions suit you best.
pravahe schrieb:
I’m interested in how you approach planning when you want to tailor the METOD modules to a room that isn’t quite standard in size.Especially with IKEA METOD kitchens, the room dimensions and adjustments are very important. That’s why I’ve put together a simple step-by-step guide to help you customize your kitchen optimally:
- Starting point: Take precise measurements of the room, including all angles, recesses, and ceiling heights.
- Planning tool: Use the IKEA planning tool extensively to virtually arrange different modules.
- Follow the grid: METOD modules follow a clear grid—usually widths in 20cm (8 inches) increments (20, 40, 60, 80), and heights of 80 or 80+ cm (31 or 31+ inches) for tall cabinets.
- Compensate for uneven floors by using adjustable feet on the base cabinets to ensure the fronts align neatly.
- Use filler panels to close gaps between modules and walls. I recommend buying filler panels slightly larger than needed so you can cut them to fit perfectly.
- Corner solutions: Use special corner cabinets (such as carousel or swing-out drawers) to make the most of available space and avoid unreachable corners.
- Countertops: Especially with L-shaped kitchens, customizing the countertops is important. Custom cuts help to compensate for any irregular measurements.
Domau0 schrieb:
To help even more precisely: What are the exact dimensions of your L-shape? Where exactly are uneven walls? Then we can together consider which cabinet types and special solutions fit your situation.That’s a really good point—the more details you can provide, the better we can give targeted advice. It’s best to make a plan with exact measurements—even the angle of the L-shape matters. Sometimes it’s advisable to use cabinets of different depths in corners to avoid awkward gaps.
If you want, you can also share your plan (without pictures, just measurements), and then we’ll look at how to best combine the IKEA modules to fit.
