ᐅ How can BILLY shelves be updated to achieve a more modern look?
Created on: 24 Nov 2022 09:23
fiben
fiben
24 Nov 2022 09:23
I own several BILLY shelves from IKEA that have started to look a bit outdated, and I would like to modernize them without completely replacing them. I am mainly interested in options to change their appearance so that the shelves look more modern and contemporary. It is important to me that the changes are both visually appealing and relatively easy to carry out, without requiring advanced DIY skills or expensive materials.
What methods or tricks do you know to enhance the look of BILLY shelves? For example, I am considering surface treatments, repainting, or technical modifications such as new doors or different handles. Are there any experiences with combining these approaches effectively to achieve a cohesive and modern design? I look forward to constructive suggestions and ideas – including tips on specific colors or patterns.
Thanks in advance!
jeff65
24 Nov 2022 10:57
fiben schrieb:
What options are there to change the appearance so that the shelves look more modern and up-to-date?
A proven method is sanding down and repainting the surfaces, ideally in matte colors such as deep anthracite or matte white. When choosing paint, make sure it is suitable for furniture and durable.
fiben schrieb:
technical changes like new doors or different handles
Here, replacing the doors with smooth surfaces or glass sliding doors can create a contemporary look. Instead of traditional handles, handleless designs or slim aluminum profiles used as handle replacements are recommended, as they significantly refine the overall appearance.
Tip: Combining repainting with replacing individual elements results in a personalized look that stays far from standard, without being very expensive or complicated.
kibutar
25 Nov 2022 13:11
fiben schrieb:
What methods or tricks do you know to visually enhance BILLY shelves?
It’s worth systematically redesigning the shelves by considering both materials and functionality.
First, I recommend thoroughly degreasing the surface and then applying a primer, especially if you plan to paint the shelves. Applying multiple coats of paint will help make the surface more durable.
Another option is to add handles: there are various possibilities, from minimalist leather pulls to metal handles in brushed stainless steel, which can be easily attached using special screw sets.
An important aspect is integrating doors. Different types of glass (frosted, tinted, or even with modern patterns) can completely change the look of the shelf. Alternatively, you can use stylish magnetic catches that hide the hinges, giving a sleek and high-quality appearance.
If you want to add color accents, I suggest using contrasting colors for the back panels or shelves, such as dark blue or warm gray, to create interesting focal points.
Finally, make sure all materials coordinate well to create a harmonious overall impression. Are you planning to use the shelves in the living room or another space? This often significantly influences the choice of colors and finishes.
Elias
26 Nov 2022 17:29
jeff65 schrieb:
Instead of traditional handles, handleless options or slim aluminum profiles as handle substitutes are recommended
I completely agree. Additionally, I would add that BILLY shelves can also be modernized by using lighting units. LED light strips installed on the inside sides create a high-quality effect and give the shelf a special atmosphere.
kibutar schrieb:
Contrasting colors for back panels or shelves, such as dark blue or warm gray, to create striking accents
That really brings the shelf to life. Personally, I have had good experiences with removable furniture films, which allow you to quickly customize back panels and shelves. Unlike paint, these films can be changed anytime if you want a new look.
I understand you want to modernize the shelf without too much effort or expense. My tips offer a good balance between effort, design, and flexibility. Good luck! 🙂
