ᐅ How can you touch up the color on a damaged Billy bookcase?
Created on: 24 Jul 2021 08:37
Lusan35
Lusan35
24 Jul 2021 08:37
Hello everyone, I recently have a Billy bookshelf from Ikea that has developed some signs of wear and small scratches over the years. The white surface, in particular, looks quite worn in some areas. I would like to touch up the color to maintain the original appearance, but I don’t want to completely repaint it. My question is: How can a damaged Billy bookshelf be touched up color-wise so that the repairs are not too noticeable and the surface doesn’t look uneven afterward? Which materials or techniques are suitable for the edges and flat surfaces, especially for the white finish? Tips on appropriate markers, paints, or other methods are very welcome, including advice on preparation and finishing treatments. Thank you in advance!
ritotar
24 Jul 2021 09:12
Hey Lusan35, your Billy shelf sounds like a great opportunity for a small DIY project! 🙂 For the typical damage on Billy shelves, I’ve had good experiences with furniture or touch-up pens that are available at hardware stores—specifically for white surfaces. They apply nicely and cover small scratches and chips quite well. It’s important to clean the surface thoroughly beforehand and lightly sand it so the paint adheres better.
Lusan35 schrieb:
...How can I touch up a damaged Billy shelf so the spots don’t stand out too much...?
That’s really the tricky part. Simply brushing it on can quickly look patchy, so it’s better to apply thin layers in several coats. If there are deeper scratches, you might want to fill them with putty first. This way, you get a nice, even finish. Good luck with the restoration! 😉
gadalu
24 Jul 2021 10:05
As an addition: For a visually appealing repair on a Billy shelf, I recommend first roughening the repair area with fine sandpaper (grit 220-320). This helps the paint adhere better. Afterwards, you can use a suitable water-based touch-up pen or acrylic paint, as these work well with the melamine-coated surface.
For edges, it can be helpful to use a special edge-protection varnish that remains flexible and is less likely to peel off.
ritotar schrieb:
It is important to clean the surface well beforehand and lightly sand it
I agree; this is an essential step to ensure the durability of the repair.
Elijah42
24 Jul 2021 11:24
Furniture touch-up markers are the simplest solution. Clean the surface first and lightly sand it. Allow proper drying time, and scratches will hardly be noticeable afterward.
Keatondra
25 Jul 2021 07:56
When repairing damaged shelves like the Billy, I make sure the surface is as smooth as possible. This means that if there are cracks or deep scratches, I first use a fine filler specifically designed for wood or furniture surfaces, which can be sanded well after drying.
Afterwards, I sand the area smooth with fine sandpaper. For coloring, I choose an acrylic or furniture touch-up pen that matches the exact shade of white. Some manufacturers even offer special repair kits for Ikea furniture that closely replicate the original color tone.
Lusan35 schrieb:
...how can you touch up a damaged Billy shelf to minimize the visibility of the repaired spots...
To make the transitions invisible, I often work with small brush strokes and gradually build up the color in thin layers. It is also important to seal the area with a matte clear coat after coloring to protect the shade and maintain the appearance.
TAUPLO
25 Jul 2021 12:17
Hey, here’s a little secret: I often use white nail polish to fix small flaws on Billy furniture! 😄
Sounds crazy, but it’s really practical because it’s liquid, dries quickly, and can be applied in very small amounts. Of course, clean the area first and ideally lightly sand it.
But obviously, for larger surfaces this isn’t suitable, and then a proper furniture touch-up pen is the way to go. So, depending on the size of the damage, give it a try – for tiny white scratches, nail polish is a great hack 😉
