Hello everyone!
Although we are from Austria and building here, we have been following various posts in this forum for some time. There are many creative minds here, and I really appreciate your advice in the other discussions.
We ourselves have been in the house planning phase for quite a while. We recently purchased a plot of land south of Vienna and plan to start construction in 2020. We want to build with solid construction methods, but we are still deciding between brick (which is very common here) and aerated concrete blocks (we really like the kit house concept from Ytong based on what we’ve heard so far, although it is quite rare in our area).
Efficiency in the use of living space is very important to us (no unnecessary features, no long hallways, no balconies or bay windows), as well as in the building services (heat pump, controlled mechanical ventilation system, etc.).
I assume there isn’t much experience here with Austrian building regulations, so I will try to answer any questions that come up as quickly and competently as possible.
Here is the completed questionnaire:
Zoning Plan / Restrictions
Plot size: 604 m² (6500 ft² approx.)
Slope: No, completely flat
Site coverage ratio: (not applicable here) - 32% buildable area
Floor area ratio: (not applicable here)
Building setback lines and boundaries: front setback 3 m (10 ft), side setback 3 m (10 ft) or half the eave height of the adjoining façade – whichever is greater, rear setback 3 m (10 ft)
Edge building restrictions: within the setback zone up to a maximum height of 3 m (10 ft)
Number of floors: not specified in the zoning plan
Roof shape: no restriction according to zoning plan
Architectural style: no restriction
Orientation: no restriction
Maximum height/limits: max. building height 6.8 m (22 ft) (eave height)
Other requirements: none
Style, roof shape, building type: classic rectangular shape, gable roof or staggered shed roof, simple building form without bay windows or dormers, no balconies!
Basement, floors: basement (gym, workshop, laundry, mainly storage), ground floor (living areas + guest room), upper floor (bedrooms)
Number of occupants, ages: male 28, female 34, child 0.5 years, child 11 years (every second weekend + school holidays)
Space requirements ground floor, upper floor: ground floor (shower bathroom, guest room/home office/play/multi-purpose room, living room, kitchen, pantry), upper floor (bedroom including walk-in closet, 2 children’s rooms, bathroom), basement (gym, laundry, storage, workshop)
Office: family use or home office?: 80% family use as playroom, 10% home office, 10% guest room
Overnight guests per year: approximately 5, mainly relatives visiting for various celebrations from afar
Open or closed layout: open plan
Conservative or modern construction: rather conservative but open to “unconventional ideas”
Open kitchen, kitchen island: open kitchen with breakfast bar
Number of dining seats: permanently 6, at family celebrations minimum 12 temporarily, >16 long term
Fireplace: no
Music/speaker wall: no – but large TV frequently used
Balcony, roof terrace: definitely no!
Garage, carport: carport within the setback zone (on the north side?)
Vegetable garden, greenhouse: definitely yes! Gardening is a big wish and the main reason for the whole project
Other wishes/special features/daily routines, explanations if desired: The house should be as efficient as possible (during construction and especially in operation), therefore no awkward bay windows etc. (ratio of surface to volume)
Additional requests: controlled mechanical ventilation system, laundry chute, non-load-bearing partition wall between the children’s rooms so it can be removed in a few years if the older child no longer lives at home. The most important thing is a large garden, so that’s why the basement is desired to minimize the building footprint. The kitchen must be large enough for at least two people to cook at the same time – this is currently a problem in our apartment.
Designed by: DIY with a lot of input from planners
What do you like? Why?: almost all wishes implemented
What do you dislike? Why?: pantry is quite small, upper floor still not quite perfect, niche in the corridor as storage replacement for vacuum cleaner etc.
Price estimate according to architect/planner: €430,000 turnkey, €350,000 “turnkey with owner involvement”
Personal price limit for house, including fixtures and fittings: €350,000 in shell and core condition is the goal, with a comfortable buffer, but that would be our ideal
Preferred heating technology: heat pump with ground source collector (trench collector)
Note: We are not under time pressure for planning or construction. We are very willing and able to do much of the work on the house ourselves. Providing appropriate “self-performance proof” for the bank is not a problem either. This helps keep construction costs low.
If you have to give up something, which details/finishes
- could you give up: almost everything except the pantry and open kitchen
- could you not give up: pantry, open kitchen, and preferably not the controlled ventilation
A mix of many examples from model home parks, magazines, and many discussions with planners/architects etc.
All the rooms we imagined are present, relatively short circulation routes, hardly any wasted space
What do you think of the design? Where do you see potential for improvement? Placement of laundry chute?
I look forward to your opinions and comments!
your Gugelhupf
Fireplace: no
your Gugelhupf
WilhelmRo20 Mar 2019 12:56Gugelhupf schrieb:
I have added some measurements, The ground floor is still missing.
Gugelhupf schrieb:
With a maximum building height of 6.8m (eaves) / 8.5m (ridge), sloped roofs are not necessarily required. Okay, a gable roof often automatically suggests knee walls, which is why I mention it. For example, I also have a maximum building height, BUT with an additional restriction of a maximum 80cm (31.5 inches) knee wall.
Gugelhupf schrieb:
Dining table is original dimensions Nice, but still mark the distances to the wall,
Gugelhupf schrieb:
since there is no kitchen yet? Then no one can tell you if a kitchen will actually fit there! Kitchen units are usually 60cm (24 inches) deep. Mark stove, oven, sink, refrigerator. Again: just Google Ikea, or do you want to build your house and then suddenly realize the kitchen doesn’t fit?
Gugelhupf schrieb:
Landing stairs are definitely not mandatory Your staircase is only 2m (6.6 feet) wide, please redraw it at 2.33m (7.6 feet).
By the way, it’s your house, but you don’t seem to put much effort in. I would have liked to see a lot more measurements, and you draw just two dimensions and shift the washbasin (probably because you realized it’s too tight in the bathroom), but completely ignore the ground floor… don’t expect much help then.
Off-topic:
Gugelhupf schrieb:
I can’t fully follow your calculation now, I also don’t understand your calculation of 430k (430,000) turnkey (which is NOT move-in ready) versus only 350k (350,000). But if you don’t want to talk about the most important aspect of building a house (whether the money will be enough) here, that’s your choice.
I’m just wondering how a fixed price of 430k (430,000) can even exist when there isn’t even a final floor plan yet? Or if selections have not been finalized? Or whether the additional construction costs are included in the 430k “contract”(?).
WilhelmRo schrieb:
I just wonder how the fixed price of 430k can even exist when there isn’t even a finalized floor plan yet? And when no selections have been made? Or whether the additional construction costs are included in the 430k "contract"(?) at all?Well, there are general contractors who will sign a contract with you under certain conditions, where the house size is fixed. The floor plan can still be adjusted.
Apart from that, the headline states 135 sqm (1453 sq ft) and your calculation is based on 160 sqm (1722 sq ft).
WilhelmRo20 Mar 2019 13:52face26 schrieb:
Apart from that, the headline says 135m² (1450 ft²) and your calculation is based on 160m² (1720 ft²). Yes, that was my mistake. But:
Gugelhupf schrieb:
Price estimate according to architect/planner: €430,000 turnkey, €350,000 “turnkey with owner’s contribution” What is that supposed to mean? An €80,000 sweat equity mortgage? That equals three skilled workers working 30 days each with 9-hour days... And it smells like “I only have €350k and try to convince myself and the bank with €80k of own work.”
Gugelhupf20 Mar 2019 14:32kaho674 schrieb:
Just for clarification:
- Where is the parking space?
- The yellow area is supposed to be the garden – does the rest also belong to the plot? Or is the black rectangle the neighbor’s property? Please define the exact property boundaries.
- The wall thicknesses seem a bit inconsistent to me. What wall thickness should the exterior wall have?
Common practice for sketches is 40cm (36.5 + plaster). If higher energy classes are to be achieved, please explain. Interior walls are well represented with 20cm (17.5 + plaster) for load-bearing and 15cm (11.5 + cladding) for non-load-bearing.Hi Kaho,
thanks for joining the discussion here – I had secretly hoped for that.
I apologize for the admittedly rough sketch of the site and neighboring properties.
Here is the explanation:
The yellow-marked plot is ours – almost rectangular (the northern corner is about 87°) with approximately 16 x 38m (52.5 x 125 feet). The black rectangles are meant to represent the neighboring buildings. To the north, the neighbor is quite far from the boundary; to the south, there is a playground (which the local authority has confirmed will not be developed anytime soon) and a neighbor with a garage directly on the property line.
If desired, I can provide a more precise drawing (albeit in pencil) later on.
Since we are seriously considering a Ytong flat-pack house, the wall thicknesses have been adapted accordingly.
Exterior walls are monolithic Thermoblock 50cm (about 20 inches) + 2cm (0.8 inches) plaster according to the data sheet, totaling 52cm (20.5 inches).
Non-load-bearing interior walls are 12cm (4.7 inches) + 2cm (0.8 inches) plaster = 14cm (5.5 inches).
Load-bearing interior walls are 25cm (9.8 inches) + 2cm (0.8 inches) plaster = 27cm (10.6 inches).
The bathroom walls on the upper floor are, for theoretical reasons, also assumed to be made of Thermoblock but 40cm (15.7 inches) + 2cm (0.8 inches) plaster, in order to allow for higher room temperatures in the bathroom – but this is just a consideration.
We expect to achieve an energy rating comparable to that of a passive house.
I hope this clears up the uncertainties?
What is this? An €80k sweat equity? That’s like 3 skilled workers for 30 days each, working 9 hours a day... And that smells like "I only have €350k and I’m trying to convince myself and the bank with €80k of own labor".To clarify the financial situation now:
I won’t go into detail about the own funds, but they are definitely sufficient.
We have a bank financing commitment for over €400k at our desired terms (which will definitely not be fully used).
State funding is about €50k.
I hope this settles the tiresome topic of money for now.
The target budget of €350k–450k for the house does not come from not being able to spend more, but mainly from not wanting to spend more. If it’s necessary to meet our requirements, then so be it... but the goal is definitely to keep costs low.
One thing this forum has to be credited for is clarifying what "turnkey" really means. I wasn’t aware at the time of the significant additional costs sometimes charged for what is considered "standard" equipment. Since you’re already budgeting around 450,000 (currency), your expectations probably won’t be low. So, be prepared to be surprised by what you might have to give up in the end.
