Hello, my wife and I are currently working on designing our floor plan. When creating the floor plan, should only the exterior wall structure (brick or sand-lime brick masonry) be considered, or the entire exterior wall including masonry, insulation, brick veneer, etc.?
Martial.white21 Apr 2021 16:51What is the floor plan intended for?
Sorry, had to type quickly earlier...
@Martial.white
It's about a floor plan for a house (bungalow). We want to draw the floor plan ourselves and consider as many details as possible. Later, the architect will only need to make minor adjustments.
Yes, I know I can't think of everything, but of a lot!
@andimann
Perfect, that’s what I wanted to know.
And for the interior walls, 1cm (0.4 inch) plaster + wall + 1cm (0.4 inch) plaster, right?
@Martial.white
@andimann
A-SPULG schrieb:
Try to consider as many details as possible. You can't do that as a layperson!
Sorry, building a house and its technology is complex; there is a multi-year degree for that!!!
You don't even know the exact wall thickness. I simply assume that you are not familiar with the fundamental principles of designing a house according to all the rules of craftsmanship and engineering, including structural calculations.
A-SPULG schrieb:
Later, I will go to the architect, who should only make minor corrections. Stick to rough sketches and write down your space requirements, then let a trained professional take over.
Trying to recreate a layperson’s design according to technical structural rules can be extremely costly and may still be executed with errors, because it cannot be done otherwise.
