ᐅ Incorrectly drilled holes in IKEA PLATSA – how to fix?
Created on: 1 Aug 2021 09:12
TILEPLO
TILEPLO
1 Aug 2021 09:12
I recently assembled an IKEA Platsa wardrobe system and noticed during assembly that some of the pre-drilled holes were incorrectly positioned. This causes the joints not to fit properly or the holes not to align with the dowels. I suspect it might be a manufacturing defect or that I made a mistake during the build.
Has anyone had experience with how to best fix incorrectly placed holes to still ensure the wardrobe is stable? Are there any practical tips to correct or conceal the holes without having to replace the entire panel?
I would be very grateful for advice on how to properly handle PLATSA panels and connectors!
fiman
1 Aug 2021 09:27
If the holes are too large, mix wood shavings with wood glue, fill the hole, let it dry, and then drill again. For incorrectly placed holes, you can also use a wooden batten for reinforcement.
Lamar
1 Aug 2021 10:05
Sure, that always sounds simple, but honestly – how reliable is that really? IKEA furniture isn’t made to last forever, and when you start doing these kinds of quick fixes, it’s actually a sign that you might want to avoid that product. Instead of patching things up, it’s better to buy everything from a hardware store that’s actually built to last.
TILEPLO
1 Aug 2021 11:33
Lamar schrieb:
Of course, it always sounds so simple, but honestly – how stable is it really?
That’s a valid question. My goal isn’t to create a perfect new piece, but rather a functional and reasonably stable repair without unnecessary effort or buying new parts. Most PLATSA components are MDF-based rather than solid wood, so you have to experiment a bit with repair methods.
I’ve considered filling the drill holes with matching wooden dowels instead of just covering them up. You lose some flexibility that way, but the joint stays more secure.
Also, how well does wood glue actually hold on these MDF panels? Does anyone have experience with how long such a repair lasts?
RETRAVIS
1 Aug 2021 13:47
Regarding the stability of repairs for incorrect drill holes in MDF-based panels, such as those used in the IKEA PLATSA system, there are some proven methods:
- First, fill the hole with wood filler or a mixture of wood glue and wood wool. Allow it to cure completely.
- For better stability, you can then re-drill the hole and insert a suitable wooden dowel.
- Alternatively, using metal connectors or angle brackets can reinforce the structure at the stressed points.
- Avoid drilling holes that are too large whenever possible. If panels are severely damaged, it may be better to replace the part.
Wood glue generally bonds well with MDF, but combining it with filler material significantly increases the load-bearing capacity of damaged areas. When screwing into filled holes, it is advisable not to place screws too close to the edge to prevent tearing out.
The most important aspect is careful preparation and allowing sufficient curing time of the materials before proceeding with assembly.
bauku
2 Aug 2021 08:19
Great tips from RETRAVIS!
I had exactly the same problem with my PLATSA and used wood filler. It held up really well, and the cabinet is rock solid!
What motivated me especially: you can hide the repaired spots behind cladding or paint over them, making them almost invisible.
Don’t despair; there’s always a solution! Just take it step by step, and the repair will work out!
