ᐅ Fence height adjacent to the neighbor and windows in the boundary wall
Created on: 28 Nov 2019 09:58
Climbee
Our dear neighbors… I’ve mentioned this a few times before.
But anyway: both of us (including the neighbors) want a privacy fence between our properties. So far, we had planned to have a landscape gardener propose a garden design, including this privacy fence, and then coordinate it with the neighbors.
A lot has changed since then, and we no longer plan to coordinate; we want to install the tallest possible fence.
As far as I know, I can put up a fence up to 1.80 meters (5 feet 11 inches) high without additional permission.
My question is: from which ground level is this measured? We have a slightly sloped plot, and on the side where the privacy fence is planned, we will not raise the terrain but will extend the terrace into a balcony. So, there will be no retaining wall underneath, just support columns on which this “quasi” balcony will rest.
The height difference to the neighbor’s property should be about 100–110 centimeters (39–43 inches) at the highest point.
Am I allowed to measure the 1.80 meters (5 feet 11 inches) from my (higher) level, or is the natural ground level decisive?
The building permit originally included a retaining wall at this spot, which, as mentioned above, has now been replaced by support columns (this is the current planning stage; if we need a wall to reach the 1.80-meter (5 feet 11 inches) privacy height, we will build one).
Second pain point:
The neighbor’s garage is built on our boundary line, and in the boundary wall there is a window facing our property, which was neither approved nor registered in the land register. This is a standard wooden window that opens. At one time, there were shutters installed that extended onto our property, but now only the brackets remain, which still protrude about 15 centimeters (6 inches) onto our land.
As far as I know, this kind of window should generally meet fire resistance class F90—but I don’t really care; that’s for their fire insurance to sort out.
The protruding shutter brackets bother us because you can catch on them—they’re simply in the way. Also, after a few incidents, we would prefer that this window cannot be opened and that the neighbors can’t look into our yard there (we actually want to create our main terrace in that area).
If the neighborhood were friendly, I wouldn’t mind at all, but here…
In Bavaria, there is a so-called window protection law (Art. 43–45 AGBGB):
Windows and any kind of light openings that are less than 60 centimeters (24 inches) from the property boundary must, at the neighbor’s request, be designed so that up to a height of 1.80 meters (5 feet 11 inches) above the floor level of the lit room (approximately eye level) neither opening nor looking through is possible. When using opaque glass blocks, no impairment to the neighboring property is expected; therefore, exterior walls with such light openings are permitted within the 60-centimeter (24-inch) protection zone.
I also found this:
A peculiarity of the Bavarian regulation is that it depends on the use of the neighboring property. For the owner to invoke the window protection law, their property must be either developed or used as a courtyard or garden. If a previously undeveloped property is later built on, from that point onward the window protection law can be enforced, meaning windows that are located within the boundary distance in exterior walls on the adjacent property must be modified as required by Art. 43 AGBGB at the neighbor’s request.
Does this mean I can demand that the window be modified accordingly?
Can I also plan something in front of the window? The wall looks awful, and as part of the garden design, we will definitely do something there. It won’t come down to me repainting the neighbor’s wall every two years (he unfortunately installed bargeboards on the boundary side with no gutter, so water drips onto the wall causing stains—no matter if we paint it, it will look bad again after two years). To what extent do I have to consider the window? Or could I just put up a wooden fence in front of it?
What can be done about the really obstructive brackets? Are we allowed to simply remove them, or do I have to request the neighbor to do so?
Here is a picture (from long ago – instead of the little trees, our garden furniture is now there *g*), so you can get an idea:
If you look closely, you can see the brackets (we will just leave the fact that the windowsill also protrudes onto our property as it is).
We’re currently planning the garden, so these questions are very urgent right now.
Second pain point:
I also found this:
Thank you for your feedback – I’m starting to think that we have been too "soft."
The idea of using a mediator or arbitration board isn’t bad; I’m considering that. Maybe the lady will be clearly told what she simply has to accept and what she should definitely avoid doing (cameras). I will discuss this with my husband. I have already found the contact details for the arbitration board responsible for us.
HilfeHilfe29 Nov 2019 13:16Climbee schrieb:
Thank you for your feedback – I’m starting to think that we might be too “soft” on this.
The idea of a mediator/arbitration board isn’t bad, I’m considering it. Maybe that way the lady can be firmly told what she simply has to accept and what she absolutely must refrain from doing (cameras). I will discuss this with my husband. I’ve already found contact info for the arbitration board responsible for us. I don’t know. I’m strict when it comes to banning someone from the property. Where would we end up if privacy is not respected?
Hello
A trail camera is not the same as a video camera.
I can set a trail camera to only trigger when a living being (heat is the trigger) is within a certain distance (e.g., 5 meters (16 feet)).
Once, in my garden, it even captured two men wearing balaclavas. It didn’t really serve a purpose, but it was interesting.
Steven
Steven
I have a general question about building on a property boundary. Normally, you are allowed to build an extension directly onto a boundary wall, right? This is often done with garages. Both neighbors have a garage on the property line, and they are built together. Often, there is quite a gap in the construction years, so it doesn’t have to be done at the same time.
I would like to improve the look of an ugly garage wall with a natural stone wall; so the question would be how to enhance the wall without requiring ongoing maintenance. We would like to build an extension onto the wall, but just a wall—no garage or garden shed.
What should we consider here? Apart from the issue of windows, like whether we are allowed to brick them up or not, which is not the point now. Can we simply build onto the existing wall?
You weren’t allowed to build in a vacant lot anyway!
Why disturb their peace?
I’m not saying new housing developments here are any better, but their problems aren’t yours, and vice versa.
You can’t choose your neighbors (meaning those ones). But you can choose yours!
You talked to those neighbors beforehand, right? As far as I remember, they were already problematic before.
