ᐅ Has anyone installed KALLAX wall-mounted—how much weight can it support?
Created on: 25 Sep 2024 18:23
MupeoHello everyone,
I’m considering mounting an IKEA KALLAX shelf unit on the wall, but I want to get an idea of how much weight it can actually hold. Has anyone here had experience hanging a KALLAX on the wall?
Specifically, I’m interested in:
- What is the maximum weight you have stored on it (books, decorations, folders, etc.)?
- What mounting materials did you use and how did you prepare the wall (e.g., wall plugs, screws, types of walls)?
- Did you encounter any issues with sagging or damage to the frame?
- Would you recommend wall mounting for larger KALLAX units, or only smaller ones?
I would really appreciate your experiences and tips, as I want to mount the shelf space-saving but also make sure nothing breaks or falls down.
Mupeo schrieb:
How much weight have you loaded on it at most (books, decorations, folders, etc.)?Regarding load capacity: The KALLAX is basically designed as a freestanding shelf, not specifically for wall mounting. This makes a difference in load limits, as the side panels are not designed to handle tensile forces from above.
When mounted on a wall, the limiting factor is usually the fasteners and the wall itself – concrete walls obviously provide more support than drywall. If you are storing heavy items, I recommend always using heavy-duty anchors or similar and screwing directly into load-bearing parts of the wall (e.g., studs or masonry).
Mupeo schrieb:
Have there been issues with sagging or even damage to the frame?Sagging occurs mostly with larger shelves, especially when loaded in the middle. I once mounted a 4x4 KALLAX on the wall and the bottom rail bent slightly downwards, but this was fixed by adding a reinforcing strip on the shelf bottom. Without such reinforcements, I would advise against wall mounting for 4x4 units or larger.
Mupeo schrieb:
What fastening materials did you use and how did you prepare the wall?I used heavy-duty anchors (for concrete) and 6 mm (1⁄4 inch) screws, with screw length depending on wall thickness – at least 7 cm (2 3⁄4 inches) of solid wall behind. For drywall, reinforcement with additional mounting plates is absolutely necessary.
If you want, I can send you a detailed guide on how I proceeded, including a materials list and preparation steps.
Regarding wall mounting of KALLAX, I can add the following: It is definitely possible to mount the shelf hanging on the wall, but the installation should be taken seriously and appropriate fasteners should be used.
It is helpful to assess the load-bearing capacity of the wall before starting installation. Load-bearing walls are ideal. For drywall or lightweight construction walls, special anchors or an additional support structure should be used.
In general, IKEA offers wall mounting accessories specifically for the KALLAX system. These should be used whenever possible to increase stability.
Assembly: Always fasten screws with appropriate anchors into at least 2 points, preferably 3 or 4 depending on the shelf size. It is best to choose screws that securely connect not only to the wall but also to the cabinet components.
If you are new to DIY installation, don’t worry, it is manageable with some patience. The key is to distribute weight properly and avoid placing overly heavy items into individual compartments.
sanjon schrieb:
The important thing is: heavy-duty anchors in solid walls, otherwise it won’t hold.That is exactly the point. The load-bearing capacity of a hanging KALLAX mainly depends on the wall mounting.
I also recommend ensuring a sufficiently large contact area between the shelf and the wall, in addition to using the correct anchors, so the load is better distributed. Especially for taller units, additional brackets or steel profiles might be useful to reduce tensile forces.
Furthermore, the load per shelf should not be underestimated: binders or heavy books can easily weigh 10–15 kg per shelf (22–33 lbs). Regular inspections are advisable, especially with wall-mounted installations.
Kinbu schrieb:
It is helpful to assess the load-bearing capacity of the wall before starting installation.Absolutely right, that is crucial. Here’s a tip from me: if you are drilling into a masonry wall and can’t find a suitable anchor, chemical anchors can also help – they offer particularly high tensile strength.
nubar schrieb:
regular inspectionsExactly. Visible cracks in the wood or loose screws are warning signs that should not be ignored.
Mupeo, if you provide the dimensions of your KALLAX and roughly what you plan to store there, I can give you a targeted recommendation on which types of anchors and fixings are necessary.
