ᐅ Has anyone ever soaked a KALLAX in basement moisture?
Created on: 17 Jun 2016 18:27
ansika
ansika
17 Jun 2016 18:27
Hello everyone, I have a specific question for the community: Has anyone ever intentionally or unintentionally placed an IKEA KALLAX shelving unit in a damp basement environment, or left the furniture exposed to moisture? I am especially interested in how the material – those particleboard panels – behaves under prolonged exposure to dampness. Are there any experiences with swelling, warping, or even mold growth on the edges? I am planning to install such a shelf in a basement that unfortunately isn’t completely dry and want to know if this makes sense or if I should rather use a different material. Thanks in advance for your insights and any tips on moisture resistance or best practices in such situations!
TEKIN
17 Jun 2016 19:15
ansika schrieb:
Has anyone here ever deliberately or accidentally placed a KALLAX shelf from IKEA in a damp basement environment or allowed the furniture to become damp there?
The KALLAX shelf is made of lacquered MDF or particleboard, which is not designed for damp conditions. Prolonged exposure to moisture usually causes swelling, loss of structural strength, and warping. There is also a risk of mold developing on the edges, especially if the shelf is not adequately ventilated.
I would generally advise against using it in a damp basement. If no alternative is available, the furniture should be additionally protected, for example, by applying a sealant or placing a barrier between the wall and the shelf. Ventilation and minimal air circulation are also essential.
kloreo
17 Jun 2016 19:47
I can only confirm this. I had a similar shelving unit in the basement, and after a short time the material started to swell.
I then removed it and replaced it with plastic shelving.
neo59
18 Jun 2016 08:05
kloreo schrieb:
After a short time, the material swelled.
I am interested in the exact timeframes in which the damage occurred. Saying "short" is a bit vague – could you clarify that?
Also, how damp was the basement exactly? This needs to be differentiated, as some Källax shelves perform better in so-called "moisture-prone" basements that are not wet compared to truly damp, moldy basements.
Furthermore, is there any evidence that impregnation significantly reduces the problem? Often, accidentally introduced moisture also causes other issues that cannot be generally attributed to the material.
JONKO
19 Jun 2016 12:37
ansika schrieb:
I'm especially interested in how the material – these particle boards – behaves under prolonged moisture exposure.
I accidentally left a KALLAX shelf in a damp basement – and yes, it visibly warped. The edges became wavy, and in some areas, the surface started to blister.
It’s important not to be too discouraged by this. When using basements, it’s best to protect furniture from moisture or switch to plastic or metal shelving.
I didn’t notice any mold, but I understand that poorly ventilated and continuously damp areas are particularly prone to mold growth.
