ᐅ Garden Fence Height 120 cm: Double Wire Mesh Fence 6/5/6 or 8/6/8?
Created on: 20 May 2021 18:08
ShawN46
ShawN46
20 May 2021 18:08
I want to install a fence made of double wire mesh panels on top of a garden wall. Now I’m wondering if the panel thickness of 6/5/6 at a height of 120cm (47 inches) is sufficient or if it will be too flexible and I should rather use 8/6/8? If it makes a difference, the posts will be anchored with dowels and not concreted in, and no privacy slats will be installed!
Thanks in advance!
AxelH.20 May 2021 20:02
We have used 6/5/6 glass in 100cm (40 inches) and 120cm (47 inches) sizes, with posts screwed onto L-shaped concrete blocks. This holds very well.
rick201824 May 2021 06:25
I would also choose 8/6/8 for lower heights. It’s simply more stable. The price difference is not significant for a "standard" plot of land.
hanghaus2000
24 May 2021 08:10
I'll ask just to be sure: How tall is the garden wall? What is it made of?
ShawN46
26 Oct 2021 09:50
a quick update: I followed rick2018’s advice and installed 8/6/8 glazing, but only 100 cm (39 inches) high, which was more than enough. I wanted to avoid regretting the slightly higher cost later, as I found the 6/5/6 panes a bit too flexible (although they would probably be stable enough).
I do have one question: The screws mounted in the base plate don’t look very neat and somewhat spoil the overall appearance of the fence, in my opinion. Is there some kind of cover plate or similar for this? I know from handrails that the fixings are often concealed with a cover rosette. How have you handled this? Or did you just leave the screws exposed?
hanghaus2000
26 Oct 2021 10:19
Please show the fastening detail.
