ᐅ Floor Plan for a 150 m² Single-Family House (Slope Site, Basement, Secondary Apartment) – Feedback on Efficiency and Layout
Created on: 21 Mar 2026 14:09
NapoleonKN
NapoleonK21 Mar 2026 14:20Hello dear building professionals,
we are planning a single-family home with a granny flat on a slope and have already given it a lot of thought.
I would like to take advantage of the forum's opportunities to gain new insights from the broad expertise here, get a realistic evaluation, and possibly improve the plans.
Access will be exclusively from the south, via the street side.
The property is located on a hillside, specifically a south-facing slope. The terrain rises from south (the street side) to north towards the garden and natural area.
The orientation of the site is as follows:
- South: street / driveway
- North: garden / forest or natural area
- East: right side of the property
- West: left side of the property
The house will be positioned roughly at the building line of the neighboring houses. The south side faces the street, while the north side will be partially embedded in the slope, with earth against the uphill side.
The basic site concept is as follows:
On the south side is the sloped courtyard and driveway area with a small retaining wall at the front of the property (forming a kind of plateau). Adjacent to this are the house and carport on the main living level, followed by the terrace, and further north the garden slope transitioning into the natural area. This arrangement is intended to make practical use of the hillside while minimizing extensive earthworks.
2. Building type and structure
A detached single-family house built in solid construction with a granny flat is planned.
The design is a classical, compact, and deliberately simple building without architectural complexity. The house will have a rectangular main volume.
The building will have a basement level (souterrain) and a finished attic with knee wall, resulting in about a 1.5-story house with an additional sub-level on the slope.
The floors are structured as follows:
1. Basement / cellar level, partly embedded
2. Living level / entrance level
3. Attic / sleeping level
The planned overall dimensions are approximately 9.5 m × 9.0 m (31 ft × 30 ft). Minor adjustments within a compact size range are possible, but the building should remain cost-effective in general.
The main living area of the family apartment is planned to be 150 m² (1,615 sq ft), divided approximately into:
- Living level: about 75 m² (807 sq ft)
- Attic: about 75 m² (807 sq ft)
3. Roof
A gable roof oriented east–west is planned to maximize the use of the southern roof surface for photovoltaics.
The roof pitch will be around 35°. The knee wall will be about 130 cm (51 inches) high to make the attic fully usable with functional living spaces.
No dormers are planned. Only roof windows (skylights) will be used, aiming for a simple, cost-conscious, and photovoltaic-friendly roof design.
4. Photovoltaics
The southern roof surface should be covered as much as possible with photovoltaic panels. The system should have a clean, uniform, and visually integrated appearance without unnecessary roof protrusions.
Two roof windows are also planned on the north-facing roof side.
5. Access and outdoor areas
Access is only from the south. The aim is to make it as barrier-free as possible.
In front of the house, a yard area is planned to serve as driveway, maneuvering, and turning zone.
The entrance level is to be accessed via a ramp along the eastern property boundary. This ramp will lead from street level up to the entrance level and the house/carport level.
The following key data are planned for the ramp:
- Width about 3.0 m (10 ft)
- Practical slope of about 10–12% maximum
If necessary, a few steps (about 2 to 3) at the house entrance are acceptable. Ideally, however, the access should remain barrier-reduced and practical for daily life.
6. Parking / garage / carport
On the right side of the house (east side), a separate parking structure is planned, either as a single garage or carport.
Key points are:
- Separate building
- Not directly attached to the house
- Access via the eastern ramp
- Located near the entrance
- Slightly shifted northwards (uphill) is conceivable
The goal is a short, practical route from the parking to the house entrance on level 2, without requiring a direct connection between garage and house.
If the ramp concept proves too costly, a stairway to the entrance could be built, and the carport/garage would be placed down in the courtyard.
7. Terrace, balcony, and garden connection
A balcony is located above the basement (kitchen) and is intended to open functionally to the living area. Currently, the balcony and terrace are partly connected along the west side of the house.
It is important that the terrace transitions as close to level as possible into the northern garden. An outdoor staircase from the terrace to the garden should be avoided if possible. Minor level differences are acceptable if required by the topography, but overall the garden connection should be as direct and comfortable as possible.
8. Basement / Level 1
The basement level is partially visible on the south side due to the slope.
The intended use is flexible and functional, particularly including:
- Granny flat
- Cellar
- Technical / utility room
- Storage or multipurpose area
Two separate outdoor accesses are to be provided:
1. Private entrance for the granny flat
2. Separate access for the cellar and storage area
The basement windows should be normal-sized, functional, and economical. Floor-to-ceiling windows are not desired here. The granny flat is also planned to be suitable for future care needs.
9. Living level / Level 2
This is the main living and entrance level.
The main entrance will be on the east side and accessible via the yard and ramp. The access should be organized as barrier-reduced as possible, even though minor level differences or a few steps are conceivable.
This level will include:
- Living room
- Dining area
- Kitchen (not an open-plan kitchen)
- Pantry
- Office with guest room
- Guest bathroom with shower
The window concept for this level is as follows:
- South: partially floor-to-ceiling windows in the living area with access to the balcony
- West: large living room windows
- North: connection/view to garden and access to garden/terrace
- East: front door as well as normal windows, e.g., for office and guest bathroom
- Ventilation for pantry
It is important that the living areas have an open and bright feel but no fully continuous glass front is planned. The house should be functional, economical, and not unnecessarily glazed overall.
10. Attic / Level 3
The attic serves as the sleeping level.
Planned uses:
- Master bedroom
- Two children’s rooms
- Family bathroom (without bathtub)
- Dressing room (adjacent to master bedroom)
With the knee wall of about 130 cm (51 inches), this floor should be well usable and practical.
Window concept in the attic:
- Windows where reasonably possible
- Supplemented by roof windows in the rooms
11. Planning objectives
The building should:
- Be compact and efficient
- Be economically and cost-effectively built
- Remain constructively simple
- Be energy-efficient, particularly regarding photovoltaics
- Be flexible for long-term use
- Fit well into the hillside location
- Provide practical daily routes between driveway, entrance, living area, and garden
12. Critical points:
- Sensible integration of the house into the hillside
- Realistic design of ramp, driveway, and yard
- Location and design of garage or carport
- Size of guest WC
- Room layout on the living level (kitchen/pantry size)
- Natural lighting and usability of the granny flat
- Financially reasonable design of the basement (offset of kitchen)
3. Roof
4. Photovoltaics
Key points are:
- Separate building
- Granny flat
- Cellar
- Living room
- Dining area
- Pantry
10. Attic / Level 3
Planned uses:
- Master bedroom
- Size of guest WC
NapoleonK schrieb:
The planned building volume has external dimensions of approximately 9.5 m × 9.0 m (31 ft 2 in × 29 ft 6 in). Minor adjustments within a compact size range are possible; the structure is intended to remain cost-effective overall.
The main living area of the family apartment is planned to be around 150 m² (1,615 sq ft), divided roughly as follows:
- Living level: approx. 75 m² (807 sq ft) - Attic floor: approx. 75 m² (807 sq ft) [...]
A gable roof with a ridge running east–west is planned, so that the southern roof surface can be optimally used for photovoltaic panels.
The roof pitch is intended to be about 35°. The knee wall height will be about 130 cm (51 in) to ensure the attic is functional and everyday living spaces can be created.
No dormers are planned. Only roof windows are foreseen; the roof design will be simple, cost-conscious, and PV-friendly overall. Square-like floor plans are generally challenging and suitable for sloped sites only if there are multiple levels of elevation; on a slope with a clear direction, the axis of the house footprint is aligned parallel to the contour lines. An attic with a 35° roof pitch and a 130 cm (51 in) knee wall will never have the same usable floor area as the floor below.
Does plot 249 also belong to your property?
While I was writing, you added more illustrations showing plans that do not work (the attic floor is not feasible near the eaves due to headroom, so a complete redesign is necessary). What do the height references 391 and 5650 mean, which do not correspond with the elevations above sea level?
NapoleonK21 Mar 2026 15:49Thanks for the feedback! 11ant
We have considered positioning the house slightly offset, so not parallel to the slope or the street, but rotated slightly westward at about 11 o’clock.
Parcel 249 also belongs to the property.
The attic floor was planned with a knee wall height of 1.30m (4.3 feet), so that the 2m (6.6 feet) height line is reached quite quickly.
391 and 5650 are probably the longitude and latitude, with the elevations listed below (from the Geoportal NRW).
Hello Napoleon,
You write a lot and describe your DIY floor plan.
That’s fine—it helps to understand your ideas—but it’s not very effective.
Please complete the pinned questionnaire so I can get to know some of your needs, meaning those of the residents of this house.
If possible, please add a few photos of the plot as well.
The bathroom on the upper floor doesn’t work at all!
NapoleonK schrieb:
We planned the attic with a knee wall of 1.30 m (4 ft 3 in), so the 2 m (6 ft 7 in) height line is reached quite quickly. Well. With a 35° roof pitch, you need a full meter (3 ft 3 in) to make up the 70 cm (27.5 in). So the head end of the parents’ bed, the children’s beds and desks, as well as the passage to the shower and half of the toilet area, are all beneath that height.
