ᐅ Floor Plan – Feedback Welcome
Created on: 9 Aug 2016 21:49
Loads
I have been quietly following this great forum for quite some time.
Last week, we received the initial plans from our builder and would like to get your opinions on them.
The street side faces north.
The street slopes upward from west to east.
The plot also slightly slopes upward from the street toward the south.
We do not have a site plan yet.
We are still unsure about the recessed terrace (even though we had specified this to the planner).
What are your thoughts on this?
The bathroom definitely needs to be redesigned.
We would like a shower without any enclosure in front.
Additionally, we want to install a laundry chute.
Looking forward to your feedback and suggestions for improvement.
Best regards from Lower Franconia!
Grundriss eines Dachgeschosses mit Schlafzimmer, Gästezimmer, Ankleide, Bad und Galerie.
Grundriss eines Hauses: Erdgeschoss mit Terrasse, Küche und Wohn-/Esszimmer.
Grundriss Kellergeschoss mit Flur KG, Büro (privat), Abst. (Musikzimmer) und Garage
Zweistöckiges Haus mit dunklem Dach, Fensterfronten, Garten; Person mit Wagen am Eingang.
Einfamilienhaus mit verglaster Terrasse, zwei Personen sitzen auf der Veranda, Bäume im Garten.
Querschnitt durch ein zweistöckiges Haus mit Treppen, Dachkonstruktion und Maßen.
Außenansicht eines Hauses mit dunklem Satteldach Terrasse und zwei Personen an einer Bank
Weißes zweistöckiges Haus mit Satteldach, großen Fenstern, grünen Bäumen links und rechts.
kbt09
4 Sep 2016 18:45
Definitely better.
You might consider rotating the staircase by 90°, so the entrance isn’t right next to the front door. However, this could make the attic floor a bit tight.
Regarding the kitchen issue... swap the living and cooking areas, rotate the wood stove 90° to the right... then it will be nicely positioned between the living and dining areas and won’t be in the way.
By the way, I find those two narrow 50cm (20 inch) high loophole windows with a high sill in the kitchen area really bad. You stand in the room and feel like you’re in a basement.
The bathroom on the upper floor is too far under the roof slope.
Loads
4 Sep 2016 19:44
I had already thought about the staircase and the toilet; we will discuss that again.
If the living room is to be located where the kitchen is now, it will need to be a bit wider, right?
kbt09
4 Sep 2016 20:25
Yes, that was said without a detailed plan. I just think the floor plan still isn't quite right.
4 Sep 2016 22:07
kbt09 schrieb:
I find those two kitchen windows, only 50cm (20 inches) high with a high sill, really terrible. You stand in the room and feel like you’re in a basement.
The sill isn’t high, it’s at countertop height.
...we have the same – copied from Viebrockhaus. The advantage: it directs the view towards the ground/garden instead of the street, and you can still install wall cabinets above, which even someone of short stature can reach. It also looks very stylish if you prefer a wider but lower window.
Otherwise, I agree with you, Kerstin.
In the bathroom, it makes sense to build a partial wall under the sloped ceiling so that the bathtub and toilet fit along the 2-meter (6.6 feet) line. You can always upgrade the bathroom later; there’s enough space.
I would skip some walls on the ground floor!
