ᐅ Terraced Corner House Floor Plan in Development – Any Suggestions for Changes?
Created on: 20 Aug 2022 21:05
Bauherrin123
Hello dear forum members,
we are building an end-terrace house measuring 7 by 10 m (23 by 33 ft) without a basement. It will have 2 full floors and an attic above. Now the question is which roof we should have. I was shown a house with a 38-degree gable roof without a knee wall, which I found very nice in terms of the feeling of space. Now we have been informed that only a 35-degree gable roof is allowed for us, but with a 30 cm (12 inches) knee wall. What I didn’t realize was that our attic has a maximum height of only 63 cm (25 inches). So the attic space is very low. Now I have no basement and hardly any storage space and I’m a bit frustrated because the building permit application is now in front of me. I initially agreed that this was okay, but I would prefer a 1 m (3 ft) knee wall. The development plan only allows a maximum of 30 cm (12 inches). I’m really unsure what to choose... I don’t want to spend unnecessary money if it doesn’t make a big difference since we have a very large plot and can build storage in the garage, barn, or garden house...
What would you do?
A. 38-degree gable roof or
B. 35-degree gable roof with 30 cm (12 inches) knee wall or
C. 35-degree gable roof with 1 m (3 ft) knee wall, applying to the city office...
We would need to submit a request to the building authority to increase the knee wall to 1 m (3 ft), which would mean more effort, bureaucracy, and delays... I don’t know what it would cost or if it’s even possible, but it’s weighing on my mind because I only read online about people who built houses with a knee wall on the attic. The extra cost of $3,000–$5,000, if that’s roughly the amount, would be worth it to me if it creates nicer rooms and I get a higher attic for storage.
The second problem is that the plot is much lower than street level. We are paying an extra €10,000 to fill the plot with gravel up to street level. Now the house will be built just slightly above street level, so there will be a step at the entrance. There will be a total of 3 terraced houses, and we have the end house. In our row, two finished terraced houses from other builders are already standing next to ours. However, these are built 1 m (3 ft) above street level with 3 or 4 steps higher, so they probably look taller overall. I find this visually unappealing and also, personally, I want our house to be higher.
What are your thoughts on this?
I’m also uploading my floor plan, which I think is finished. I don’t understand how high the ceilings are; can someone tell from the plans? Inside the rooms, how high are they? And generally, do you notice anything about the floor plan?
My building permit application is ready, but I want to change it after all. It doesn’t suit me, and I’m sure it will cause trouble with the company if they have to make changes for us, but I want to be able to decide again and just need some feedback here.
Looking forward to your support!
Zweigeschossiges Haus mit Dachgeschoss; Schnitte A-A und Front-, Garten- und Rückansicht
Grundriss eines Hauses: Erdgeschoss mit Wohnen/Essen, Küche, Diele, WC, Terrasse.
Grundriss Obergeschoss: Eltern, Kind 1, Büro, Flur, Bad, Dachterrasse, Treppe.
Dachgeschoss-Grundriss mit Studio, Bad und HWR, Treppe, Türen und Maßangaben
Schematischer Gebäudeschnitt eines Hauses mit Treppen, Räumen (Büro, Flur, Bad).
Bauherrin123
23 Oct 2022 00:54
kbt09 schrieb:
Unfortunately, the number on the new drawing is not readable... but it can’t be higher than on the old drawing. You just need to compare the dimension chains on the left.
Is it easier to read here?
Section A-A of a house showing stairs, rooms (living room, office, bathroom), and roof structure.
Bauherrin123
23 Oct 2022 00:56
I will try uploading it differently tomorrow. Previously it was 63, now it is 83. I thought she had lowered the beams. I will try tomorrow to upload the files in a way that the numbers can be read.
23 Oct 2022 01:02
Bauherrin123 schrieb:
So, the height in the attic last time in the middle was 63cm (25 inches), now it’s 83cm (33 inches).
Learn for life:
Again: Screenshots with two-digit KB are not suitable for showing details!!!
So the numbers are not easy to read now. But if I focus on them, I’m also at 63cm (25 inches)… I see the measurements on the left as well, no changes at all.
My opinion: you won’t really use the space up there anyway. What do you think you can store up there? One box on each side of the hatch… You can’t walk in there, you can’t push boxes to the back because the sloping roof gets in the way. I would make good use of the knee walls / storage space under the sloping roof instead—you have plenty of that! These 63cm (25 inches) or 83cm (33 inches) are completely useless.
hanse987
23 Oct 2022 02:32
I’m not sure if I missed it somewhere, but where is the hatch for the attic ladder supposed to go? In the plans I found, I don’t see anything about it.
How is the insulation being installed up there, especially regarding the thickness? Have you already thought about what type of flooring you plan to use?
For the two storage boxes you can fit up there, I wouldn’t make such a big effort.
Bauherrin123
23 Oct 2022 19:59
Here is the image the architect sent me again. No matter how I load it, the numbers are unreadable???
Bauherrin123
23 Oct 2022 20:02
Section A-A through a multi-story house with living area, hallway, studio, office, roof structure.
Can you read this here? I tried several times. No success.
Cross-section A-A of a house with roof frame, stairs, living areas, and office spaces
