ᐅ Floor Plan Design for a Single-Family Home of Approximately 150 m²
Created on: 12 Feb 2018 18:09
chrisw81
After a long search, we signed the notarized contract for the land purchase at the end of December. We are now actively planning the floor plan. Unfortunately, the plot is somewhat awkwardly shaped (not rectangular), which creates some limitations for the layout from our perspective. We already have a first draft, but there are several areas we don’t like and are unsure how to improve. Maybe you have some ideas; we would appreciate your input.
Plot size: 601 m² (6465 sq ft)
Building envelope, building line, boundary: Building line with the house on the west side
Peripheral setbacks: 7 m (23 ft) from the street (north), otherwise the usual 3 m (10 ft)
Number of parking spaces: 2 desired
Number of floors: 1 full story allowed
Roof style: Gable roof
Design style: open construction method
Orientation: South
Maximum heights / limits: Ridge height max. 8.5 m (28 ft)
Additional requirements: Max. 100 m² (1076 sq ft) of built-up area
Style, roof form, building type: Solid construction house, rectangular, no bay windows, no projections, etc., gable roof
Basement, floors: no basement; 1.5 stories
Number and age of residents: 2 people, age between 30 and 40, possibly children later
Space needs on ground floor and upper floor: Ground floor – living/dining room, kitchen, guest toilet, utility room, office
Office: family use or home office?: family use
Guest stays per year: 20 days
Open or closed architecture: open living area, closed hallway
Conservative or modern style: conservative
Open kitchen, kitchen island: open kitchen, island without cooktop
Number of dining seats: 2-4
Fireplace: yes, chimney planned
Music/stereo wall: no
Garage, carport: carport
Further wishes, special features, daily routine, and reasons for preferences:
- A wardrobe area on the ground floor is important where coats can be stored relatively out of sight.
- On the upper floor, it would be nice to have an open gallery with a desk or similar (not a must and not necessarily next to the stairs).
- A walk-in closet would be nice but not essential.
- A storage room on the upper floor is very important since we do not have a basement.
Who created the design:
- Basic design by the construction company (FIBAV Stadthaus Vision Studio)
- DIY modifications based on online floor plans (especially Viebrockhaus Maxime 330)
What do you particularly like? Why?:
- Layout of the living/dining area and the narrowing kitchen reduces the hallway effect a bit
- Many windows in the living/dining area
- Wide hallway on the ground floor
What do you dislike? Why?:
- Few options to place furniture (dresser, wardrobe) in the ground floor hallway due to many doors
- Very large hallway upstairs, considered wasted space
- Bedroom is quite small; should be the largest room upstairs (preferably 16 m² (172 sq ft), children’s rooms rather 14 m² (151 sq ft))
- Stair placement limited by chimney location
- Door placement upstairs limited by chimney
- A staircase rotated 90 degrees (entrance next to front door) would appeal more
- Difficult to align windows upstairs and downstairs on the gable end vertically
- Floor-to-ceiling windows upstairs; wider windows with a sill height around 100 cm (40 inches) would be preferred
Price estimate by architect/planner: 200,000 €
Personal price limit for the house including equipment: 210,000 €
Preferred heating technology: gas heating
What details or expansions could you give up?
- Can do without: gallery next to stairs upstairs. Living area could also be narrower (e.g., 4.20 m (14 ft) instead of 4.47 m (15 ft))
- Cannot do without: storage room upstairs, shower in guest toilet, extra natural light in the ground floor hallway (e.g., side panel on front door or window)
Why was the design made this way? For example, standard plan from planner?
- Since the house has very little space on the south side, the house should be very narrow in order not to waste more space to the south. It should be wider so that living, dining, and kitchen areas face south as much as possible.
Were corresponding wishes from the architect implemented? No architect meeting has taken place yet.
How can the ground floor hallway be better designed to fit a wardrobe? Can the stairs be positioned better or replaced? Should the hallway be enlarged and living space reduced? How can the upstairs hallway be better utilized? Can the bedroom be enlarged? Is it possible to swap the bedroom with another room, e.g., move it to the southeast to allow a walk-in closet?
Thank you very much in advance for your criticism and suggestions!
Orientation: South
chrisw81 schrieb:
I thought so too. Definitely in the guest room. The problem is, I would prefer not to do it at the same time in the living room because I don’t want a window on that side (due to the neighboring house and the sofa).Here you write that you don’t want a window on the "side" in the living room... then I recommend the window or patio door, so the window will never bother you.
chrisw81 schrieb:
What about the window above the sofa? So far, no one has criticized it. In most houses, you see windows or even floor-to-ceiling windows behind the sofa (which makes even less sense)..I never mentioned floor-to-ceiling, did I?
And if no one has criticized it yet... you just posted the plan 2 hours ago.
From my perspective, yes, it could be removed.
But since you want it, I would say: it could be set back a bit more. Visually, it stands out from the house... I would recess it by 30-50cm (12-20 inches). However, this is not a defect, just something to consider.
chrisw81 schrieb:
What makes an "interesting" facade? Many dormers?
If you look at other providers like Viebrockhaus, you mostly don’t see anything different there either...No, not dormers. Arrangements that are designed thoughtfully so they look appealing and make sense in the floor plan.
An architect studied design as a subject and should be able to deliver more in this regard.
But I’m done with this now... I’ve shared my opinion. That’s it!
chrisw81 schrieb:
What makes a "interesting" facade? Lots of dormers? Wrong answer :-(
No, you can achieve that quite simply by not clinging to symmetry. It’s not about adding a bit more originality. Often, it’s enough to avoid limiting yourself with a fixed idea—whether that’s symmetry, a chimney, corner windows, T-shaped bathrooms, or whatever else.
It’s your house. I don’t see anything about it that I would feel the need to advise against. None of us discussing here has to live in it anyway.
Here you write that you don’t want a window on the "side" in the living room... then I would recommend the window or patio door, so the window will never bother you. Sorry, I completely misunderstood. I definitely want a window on the side, but not too close to the exterior wall so that no one can look directly at the sofa.
As far as I’m concerned, yes, it could be removed.
But since you want it, I would say it could be set back a bit more. Visually, it stands out from the house... I would recess it by 30-50cm (about 12-20 inches). However, this is not a flaw, just something to consider during planning. Wouldn’t the living room become really dark if it was removed? Moving it further back will be difficult because I still need space for the piano next to the sofa. And there shouldn’t be a window there. Originally I was aiming for 50cm (20 inches), but the architect already intervened on that.
I addressed the issue with the windows on the upper floor by shifting the bedroom and children's room windows about 20cm (8 inches) toward the exterior wall. This creates roughly 75cm (30 inches) of space between the bedroom window and the interior wall for cabinets. In the children's room, it’s less, about 40cm (16 inches), but that’s sufficient. Because of this 20cm (8 inches) shift, the windows on the ground floor now align exactly in the center.
I recreated this view—what do you think?
The chimney in the bedroom will likely be about 3.25m (11 feet) away from the exterior wall, so with these dimensions, it will be tight to achieve flush alignment with the built-in wardrobe.
chrisw81 schrieb:
These 20cm (8 inches) result in the windows on the ground floor being exactly centered. I recreated this view—what do you think? Well, it looks a bit more appealing.
