ᐅ Floor Plan Design for a Single-Family Home of Approximately 150 m²
Created on: 12 Feb 2018 18:09
chrisw81
After a long search, we signed the notarized contract for the land purchase at the end of December. We are now actively planning the floor plan. Unfortunately, the plot is somewhat awkwardly shaped (not rectangular), which creates some limitations for the layout from our perspective. We already have a first draft, but there are several areas we don’t like and are unsure how to improve. Maybe you have some ideas; we would appreciate your input.
Plot size: 601 m² (6465 sq ft)
Building envelope, building line, boundary: Building line with the house on the west side
Peripheral setbacks: 7 m (23 ft) from the street (north), otherwise the usual 3 m (10 ft)
Number of parking spaces: 2 desired
Number of floors: 1 full story allowed
Roof style: Gable roof
Design style: open construction method
Orientation: South
Maximum heights / limits: Ridge height max. 8.5 m (28 ft)
Additional requirements: Max. 100 m² (1076 sq ft) of built-up area
Style, roof form, building type: Solid construction house, rectangular, no bay windows, no projections, etc., gable roof
Basement, floors: no basement; 1.5 stories
Number and age of residents: 2 people, age between 30 and 40, possibly children later
Space needs on ground floor and upper floor: Ground floor – living/dining room, kitchen, guest toilet, utility room, office
Office: family use or home office?: family use
Guest stays per year: 20 days
Open or closed architecture: open living area, closed hallway
Conservative or modern style: conservative
Open kitchen, kitchen island: open kitchen, island without cooktop
Number of dining seats: 2-4
Fireplace: yes, chimney planned
Music/stereo wall: no
Garage, carport: carport
Further wishes, special features, daily routine, and reasons for preferences:
- A wardrobe area on the ground floor is important where coats can be stored relatively out of sight.
- On the upper floor, it would be nice to have an open gallery with a desk or similar (not a must and not necessarily next to the stairs).
- A walk-in closet would be nice but not essential.
- A storage room on the upper floor is very important since we do not have a basement.
Who created the design:
- Basic design by the construction company (FIBAV Stadthaus Vision Studio)
- DIY modifications based on online floor plans (especially Viebrockhaus Maxime 330)
What do you particularly like? Why?:
- Layout of the living/dining area and the narrowing kitchen reduces the hallway effect a bit
- Many windows in the living/dining area
- Wide hallway on the ground floor
What do you dislike? Why?:
- Few options to place furniture (dresser, wardrobe) in the ground floor hallway due to many doors
- Very large hallway upstairs, considered wasted space
- Bedroom is quite small; should be the largest room upstairs (preferably 16 m² (172 sq ft), children’s rooms rather 14 m² (151 sq ft))
- Stair placement limited by chimney location
- Door placement upstairs limited by chimney
- A staircase rotated 90 degrees (entrance next to front door) would appeal more
- Difficult to align windows upstairs and downstairs on the gable end vertically
- Floor-to-ceiling windows upstairs; wider windows with a sill height around 100 cm (40 inches) would be preferred
Price estimate by architect/planner: 200,000 €
Personal price limit for the house including equipment: 210,000 €
Preferred heating technology: gas heating
What details or expansions could you give up?
- Can do without: gallery next to stairs upstairs. Living area could also be narrower (e.g., 4.20 m (14 ft) instead of 4.47 m (15 ft))
- Cannot do without: storage room upstairs, shower in guest toilet, extra natural light in the ground floor hallway (e.g., side panel on front door or window)
Why was the design made this way? For example, standard plan from planner?
- Since the house has very little space on the south side, the house should be very narrow in order not to waste more space to the south. It should be wider so that living, dining, and kitchen areas face south as much as possible.
Were corresponding wishes from the architect implemented? No architect meeting has taken place yet.
How can the ground floor hallway be better designed to fit a wardrobe? Can the stairs be positioned better or replaced? Should the hallway be enlarged and living space reduced? How can the upstairs hallway be better utilized? Can the bedroom be enlarged? Is it possible to swap the bedroom with another room, e.g., move it to the southeast to allow a walk-in closet?
Thank you very much in advance for your criticism and suggestions!
Orientation: South
Climbee schrieb:
The exterior views are more uninspired and boring than Flair 113. Flair 113 is old news – Charm 08/15 rules
Does symmetry play a role in your house? Otherwise, I would simply ignore their wishes. No, not everything has to be symmetrical.
No, it actually turned out quite well after smoothing out all the corners.
Personally, your hallway closet would be too small for me and my husband... [emoji6] ... and it was always my goal to get you to consider more [emoji1]
And then there's the bedroom space and the window above the sofa... The hallway closet is sufficient for us, and if necessary, there’s still some space under the stairs for a few coat hooks. I don’t see that as a problem anymore. I told the architect to make the most of the available space.
The bedroom space? If I can move the window so that I can fit a decent wardrobe between the chimney and the exterior wall, that’s not bad at all. Sure, it’s not a huge bedroom, but it’s acceptable.
What about the window above the sofa? No one has complained about that so far. In most houses, you often see windows or even floor-to-ceiling windows behind the sofa (which is even less practical).
Climbee schrieb:
Why are you dealing with an architect who is so obviously unmotivated? A reasonably committed architect wouldn’t put their name on something like this. Or did you give them such strict guidelines from the start that they simply lost interest and just slapped together what you wanted, without any willingness to discuss it? I think the problem was that we created an initial draft ourselves for our house contract. It was based on a basic house plan plus our own research. Of course, it also included what was important to us (fireplace, furniture pieces, etc.). We then took this floor plan to the architect, who only checked for any major errors and then traced it. So it really depended more on the skill and experience of the house seller how the draft turned out. Ours was more focused on function rather than aesthetics, and didn’t really have many creative ideas.
It’s uncommon for the architect to create multiple drafts on their own initiative anyway, as that would take a lot of time and money.
Climbee schrieb:
Honestly, I wouldn’t spend a single dollar/pound/euro on a house like that. Of course, there are more brilliant designs, but you always have to consider the surroundings of the plot—where you can place windows and where you can’t. I would have liked a southwest corner window too, but then the neighbors would constantly be looking inside. You have to balance aesthetics and function. Dormer windows could have been added as well, but personally, I don’t find them that attractive.
That is, in my opinion, a reminder from the architect of a general contractor.Yes, it is...ypg schrieb:
If you don’t want the living room window on the west side, then just leave it out. Instead, plant a shrub in front of it. However, I would plan a patio door about 60 cm (24 inches) away from the TV wall there, so you still get some natural light from the west. Also, having multiple access points to other terraces is always a good thing. And wasn’t there a question about the northwest side and the possibility of having a terrace there as well?
This seems to be exactly the case here.I definitely want it, also for a bit more brightness. Do you really think it needs to be that close to the TV wall?A terrace on the northwest side, yes, but not an exit from the living room at this height. There is still too little direct sunlight from the west there, more towards the north, facing the street.
So a west-facing exit from the living room probably wouldn’t add much.
Flair 113 was yesterday – Charm 08/15 rules What makes a "interesting" facade? Lots of dormers?
If you look at other builders like Viebrockhaus, you usually don’t see much difference there either...
