ᐅ Experiences with moisture-resistant paint on old KALLAX units?
Created on: 23 Jun 2016 19:37
O
ontobenHello everyone,
I am planning to renovate my old KALLAX shelves for use in a damp room by applying moisture-resistant paint. Since the KALLAX units are made of particleboard, I am concerned about long-term durability and protection against moisture, as high humidity in bathrooms or kitchens can quickly cause damage such as swelling.
I am especially interested in whether anyone has experience applying moisture-resistant paint directly to the unfinished KALLAX panels. How well does the paint adhere? Are there any special preparation steps needed before painting to prevent the particleboard from swelling? And how durable is the paint in everyday use— for example, against splashes or cleaning agents?
I look forward to your experiences and tips!
Hello ontoben,
thorough preparation is essential when painting KALLAX units with moisture-resistant paint. The panels are made of particleboard, which is very sensitive to moisture. I therefore recommend the following procedure:
1. Lightly sand the surface with fine sandpaper to slightly roughen it and improve adhesion.
2. Remove dust and grease, preferably with an alcohol-based cleaner.
3. Apply an appropriate primer designed for particleboard that repels moisture.
4. Apply multiple coats of the moisture-resistant paint, following the manufacturer’s instructions for each layer.
It is important to let each coat dry completely to avoid blistering or uneven layers. Additionally, the primer protects the particleboard from swelling.
The number and thickness of the layers also depend on the usage. For heavily used surfaces, such as those near sinks, at least three coats should be applied.
I’m interested in how much moisture is actually present in your room, and whether the KALLAX units come into direct contact with water or only with humid air?
Parbo schrieb:
I am interested in how high the humidity in your room really is, and whether the KALLAX units come into direct contact with water or only with damp air?Thank you for your detailed advice, Parbo! Fortunately, the humidity in the room is rather high, but there is no constant contact with water. It is my bathroom, which is regularly used for showering, but the shelves are mounted on a wall that only gets splashes and steam, not direct water.
To make sure I don’t overlook anything: In your opinion, is a combination of primer plus three coats of moisture-resistant paint sufficient for this situation? Or are there any special protective treatments, such as impregnations, that should be applied before painting?
There are some findings from tests and practical experience regarding the quality and durability of moisture-resistant paint on particleboards used in KALLAX modules:
- Products with a high content of acrylic resins or polyurethane demonstrate better moisture resistance.
- The primer must be suitable for absorbent substrates to prevent swelling.
- Multiple coats with intermediate sanding significantly improve adhesion.
- Allowing each layer to dry thoroughly prevents surface defects.
Impregnation treatments are usually only conditionally useful, as they can affect the primer.
For moisture-prone areas, painting is a good protective measure, but complete protection against prolonged exposure to moisture is not realistic. Therefore, in cases of direct water contact, mechanical sealing or the use of special boards (e.g., MDF with a special coating) is recommended.
ontoben schrieb:
In your opinion, is a combination of primer plus three coats of moisture-resistant paint sufficient for this application?I have similar KALLAX units in my bathroom as well, but without primer and only two coats of paint. Unfortunately, after a few months, small bubbles appeared on the edges, which I found quite disappointing.
Your approach with the primer sounds reasonable.
It also reassures me to hear that I’m not the only one concerned about protection. You definitely want to avoid any damage. Please keep us updated on how your project progresses – I find this topic really interesting 🙂
