ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Sebastian79
1 May 2016 13:14
You haven't even done a hydraulic balancing, and you are just adjusting the heating system "somehow" – what do you expect?
Legurit
1 May 2016 13:40
To be honest, my consumption values are not bad. I’m curious to see your numbers once the heating is running. Saruss’s consumption is just extremely low.
Saruss
1 May 2016 13:42
I seem to have a relatively warm brine solution as well. So reaching the 25°C (77°F) supply temperature or so in April can be done effectively.
Apart from that, I used 2000 kWh in the first year, but only 1400 kWh in the last 12 months. It seems that new construction and residual moisture also play a role.
I need to check the degree days, but the winter was not much warmer than the previous one.
Sebastian79
1 May 2016 14:10
I still have to wait because tiles were installed – so there will be no heating for about 4 weeks (1 month).
Anyway, these values don’t really mean much yet, since the hydraulic balancing and fine-tuning can only be properly done next winter.
Last time, during normal operation, I had a performance factor of 6.3 ... Of course, without hot water. But I don’t consider that to be a realistic figure for the long term...
Legurit
1 May 2016 14:22
Please share your experience. I'm very interested. For April, our heating cost is 5.6. In winter, it will definitely not be sustainable.
Saruss
1 May 2016 14:24
My heat pump also only has a coefficient of performance (COP) of 4.8 at B0W35, and 5.4 at B5W35 (which is already close to the lower limit for my brine inlet temperature). At -18°C (0°F) or so, I would have a flow temperature of 35°C (95°F), but during the transitional seasons, the brine temperature is a bit higher, and the flow temperature is around 25°C (77°F), so COPs above 6 are normal. For domestic hot water, the COP decreases, but since over the course of the year you use more heating energy than hot water energy, it’s not a big issue.
In summer, the brine inlet temperature is usually closer to 10°C (50°F), and if you only produce domestic hot water once a day, the COP also doesn’t drop significantly.
