ᐅ Timer for circulation pump at the heating system
Created on: 6 Apr 2021 09:11
chewbacca123
We have a timer switch for the heating circulation pump, see the picture.
But no matter how I set it, the circulation never works as it should. I just don’t understand it!
There are three modes you can set: permanently on, permanently off, or according to the schedule (middle setting).
I set it so that, for example, it should circulate tomorrow between around 6 and 9:00 AM. But it doesn’t. Of course, I also set the current time correctly according to the small arrow. I’ve tried everything.
What am I doing wrong?
Our heating system also has an option to control the circulation, see the other photo.
According to the heating installer, this won’t work if the manual timer is activated.
It really never works as I set it—for example, at 6:30 AM, freezing cold water for 1 minute.
FRUSTRATION!
Do you have any idea what this could be? Thanks a lot
Round timer dial with 24-hour number ring, two arrows, and Off/On marking
Display of a schedule: circulation 5+2, Monday-Friday, times 06:15-09:00 and 15:00-19:00.
Mycraft6 Apr 2021 13:25
@FloHB123
Yes, that is correct. It appears to be an Ecocirc Pro, which is available in various models, including ones with a mechanical timer. However, this timer can be deactivated (as in this case), and the pump is then controlled solely by the heating system.
@chewbacca123
The electrical connection is definitely correct, but are there any other settings on the heating system that could prevent circulation or, conversely, start it independently from the electronic schedule?
lastdrop6 Apr 2021 14:35
Are you asking about heating or hot water? The second image refers to hot water.
Is the manual timer connected to the heating output or to the hot water?
Loads
8 Apr 2021 08:15
I find this installation quite unusual.
Who would install a manual timer or a circulation pump with a manual timer on a heating system that can control the circulation digitally by itself?
Is this a Novelan heat pump?
My control system looks similar.
Of course, it’s possible that the circulation pump isn’t working at all.
That often happens if these units don’t run for a longer period – they tend to get clogged with scale.
Alternatively, you can check how long the circulation times are set in the heating controller.
For example, mine is set so that the pump runs for 5 minutes and then pauses for 30 minutes.
Maybe it’s incorrectly configured.
But generally, I would probably look for a different installer...
Mycraft8 Apr 2021 09:08
Loads schrieb:
Who would install a manual timer or a circulation pump with a manual timer on a heating system that can digitally control the circulation itself?
It might be unusual, but generally, what is installed is whatever is available at the time, unless something different is specifically requested or ordered. Even a state-of-the-art pump can still have a mechanical timer attached. Most likely, this option was simply more cost-effective.
chewbacca1238 Apr 2021 12:22
Who installs a manual timer or a circulation pump with a manual timer on a heating system that can digitally control the circulation itself?
It’s possible that the circulation pump is not working at all.
This happens quite often when the pumps haven’t been running for a long time – they tend to get clogged with limescale.
Alternatively, you can check how long the circulation times are set in the heating system controls.
Mine, for example, runs the pump for 5 minutes and then pauses for 30 minutes.
Maybe it’s set incorrectly.
But in general, I would probably look for a different installer...
Yes, we do have Novelan.
The heating technician was here this morning; he said we should keep an eye on it and that the circulation pump might be broken. He made a few adjustments but didn’t explain much. My questions weren’t answered… really frustrating.
I suspect the pump really is broken. Let’s wait and see.
apokolok
8 Apr 2021 13:25
If you turn on the pump manually, you should be able to hear or feel whether it is running.
What are you waiting for?
