ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Saruss
1 Jan 2016 21:58
I don't need to add anything to what you write; everyone can form their own opinion, thanks. But please show some courage this time and don't have your posts deleted like before.
Sebastian79
1 Jan 2016 22:00
I have never had a single post deleted – whatever that has to do with courage.
If you have nothing more to add, why do you keep writing? I won’t comment on that any further.
MeisterBob
1 Jan 2016 22:05
Thank you, Saruss, for your explanation. I will think about what could be causing the issue. As I mentioned, I already understand that we are not running the most efficient system, which is certainly due to the chimney.
I only responded to the thread creator’s question and did not raise anything for discussion, so I don’t understand why Sebastian is so upset about it. I wish you all a pleasant evening!
Sebastian79
1 Jan 2016 22:07
I’m not upset – after all, it’s your money being wasted. I have no idea how you can’t seriously think this through, especially when you apparently keep an eye on the values.
Legurit
8 Jan 2016 20:43
What are your current brine outlet temperatures at the end of the cycle? I am already at 0.2°C (32.4°F) – and I’m afraid that’s not very impressive – I definitely need to check with the well driller again.
Saruss
8 Jan 2016 20:53
I just finished 1 hour of hot water generation and am now at minute 15 of the heating cycle. The brine outlet temperature is at 5.8°C (42.4°F).
