ᐅ Experiences with new handles for KALLAX doors?
Created on: 9 Feb 2023 18:07
Bryanku42
Bryanku42
9 Feb 2023 18:07
I recently fitted my KALLAX shelves with new doors and am now considering replacing the handles, as I find the original handles quite plain and not very ergonomic.
I am interested to hear about other users’ experiences with new handles on KALLAX doors:
- Which types of handles work well both mechanically and visually with the KALLAX doors?
- Are there any installation tips, for example, regarding the door material (often medium-density fiberboard)?
- How securely do different handle models stay in place over time, especially with frequent door use?
- Are screw-on handles generally recommended, or are there clever alternatives like recessed handles that are easier to retrofit?
For me, it’s important that the handle not only looks good but is also durable and practical for everyday use. I appreciate any detailed feedback, personal experiences, and recommendations!
Surela
9 Feb 2023 19:26
Regarding your question about which types of handles work well for KALLAX doors, I can share detailed insights based on my own experience and research.
KALLAX doors are usually made from a 10mm (0.4 inch) thick MDF panel with a white melamine coating. This means you need to be careful when drilling for screw-on handles to avoid chipping the surface. I recommend pre-drilling with a smaller drill bit and using special tape on the drilling spot to minimize splintering.
About the handle types:
- Screw-on metal handles are sturdy and provide a good grip. However, with cheaper models, you should watch out for rough edges on low-quality metal which can damage the material.
- Recessed or inset handles are easy to install but usually require a larger cutout in the door, which can be tricky with KALLAX MDF.
Another consideration is the orientation of the handles. Horizontally mounted bar handles make it easier to open the door by pulling, something I carefully considered before my modification.
For my handles, I also added silicone washers to reduce vibrations and prevent long-term damage to the door.
For durable, everyday use, I consider high-quality aluminum or stainless steel handles the best choice, as plastic handles tend to stretch out or break with frequent use.
Could you possibly specify how often the doors will be opened and what kind of use they will have (e.g., heavy objects behind)? This way, I can provide more targeted advice.
Lotizar
10 Feb 2023 07:44
Surela schrieb:
KALLAX doors are typically made from a 10mm (0.4 inch) thick MDF board with a white melamine coating, which means you need to be careful when drilling for screw handles
This is a very important point. I installed new metal handles on my KALLAX doors myself and can confirm that precise pre-drilling is crucial to avoid splintering.
Regarding mechanical stress, screw handles are definitely sturdy enough for normal daily use. Under heavy load, for example if heavy items are stored behind the door and it is opened frequently, the screws should be checked regularly and tightened if necessary.
Visually, simple matte handles work very well with KALLAX, as the overall design remains minimalist and uncluttered. I would generally advise against overly flashy or large handles, as they can disrupt the clean appearance.
For those looking for a truly tool-free installation, clamp or magnetic handles are an option, although durability is usually compromised.
Overall, I recommend choosing the handle style based on personal preference, ensuring secure connection through careful pre-drilling, and performing regular maintenance.
Joe52
10 Feb 2023 09:53
I find this topic very interesting because I am facing a similar decision, and your detailed question is very helpful.
Bryanku42 schrieb:
I am curious about the experiences other users have had with new handles on KALLAX doors
Personally, I have only used the original handles so far, but I don’t find them very comfortable to hold. What makes me a bit unsure is the concern that a very sturdy or heavy handle might eventually wear out or damage the door.
Therefore, I would like to know how your experiences have affected the door’s durability. Have handles become loose after months or years, or have they stayed secure?
An advantage would also be if the installation is not too complicated. Anyone who has worked with wood knows how quickly MDF can become brittle.
Maybe those who have been using such handles for a longer time could also briefly describe how the handles are to maintain – especially with materials like aluminum or plastic?
SauDietmar
11 Feb 2023 11:31
Since some technical details have already been mentioned, I would like to add my experience as clearly as possible:
1. Material choice:
- Aluminum handles are lightweight, corrosion-resistant, and durable.
- Stainless steel handles offer even more robustness but are more expensive.
- Plastic handles can be inexpensive but often wear out or deform quickly.
2. Installation:
- Pre-drilling is essential to prevent splitting when working with MDF. It is advisable to start with a smaller drill bit and then enlarge the hole to fit the screw.
- If the door is frequently used, it is recommended to use larger washers or spacer rings to distribute the load on the door surface.
3. Ergonomics:
- Bar handles are generally more comfortable than simple knobs, especially if the door is opened often.
4. Maintenance:
- Metal handles are usually low-maintenance: occasional wiping, and for stainless steel, a little polish for shine.
- Plastic handles may fade or become brittle if exposed to harsh cleaning agents.
5. Alternatives:
- Magnetic or clip-on handles can make retrofitting easier but are less durable.
One more thing: if you want comfort through soft-close hinges, plan the handle height so it does not interfere with the closing mechanism.
If you like, I can also send you a short list of sources for suitable handles.
Roberta
11 Feb 2023 13:22
Bryanku42 schrieb:
Are screw handles generally recommended, or are there clever alternatives like recessed handles that are easier to retrofit?
I only install screw handles because they are more stable. Recessed handles usually require milling work, which is more labor-intensive.
Pre-drilling helps to prevent cracks. Always use washers.
If speed is a priority, a bow handle with two screws is the best solution.
