ᐅ Experience: Water Damage and Kallax Shelving in the Same Room – How Long Does Drying Take?
Created on: 17 Jan 2020 10:43
Laherbert
Laherbert
17 Jan 2020 10:43
I recently had a water damage incident in my apartment, which mainly affected the area where I have a Kallax shelving unit. The shelf is not solid wood, but of course the material of the shelves soaks up moisture.
My main question is:
How long does it usually take for a room – including furniture like the Kallax – to dry completely when using basic methods (ventilating through windows, possibly a fan, but no professional drying equipment)?
I understand this depends on several factors, such as room temperature, humidity, how much the room is used, and the extent of the damage itself. But does anyone have experience with how many days you should roughly expect before you can use the shelf again fully without worrying about mold or odors?
I would also like to know if it’s better to take the shelf completely apart or if it can be left assembled, especially with regard to drying time. Does anyone have long-term experience or recommendations?
Thanks in advance for your insights!
refinar
17 Jan 2020 13:12
Hello Laherbert,
Regarding your question: The drying time after water damage involving furniture like Kallax units generally depends on several factors. I will try to organize this a bit:
1. Room and air conditions: Without professional drying equipment, it usually takes about 7 to 14 days, depending on ventilation, room temperature, and humidity levels. It can take longer if the humidity remains consistently high.
2. Furniture material: Kallax shelves are often made of MDF or particleboard, which can absorb water and swell depending on the extent of the damage. The shelves absorb a lot of moisture, which naturally slows down the drying process.
3. Whether to disassemble the furniture or not:
Laherbert schrieb:
“Does anyone have long-term experience or recommendations?”
Yes, definitely disassemble if possible. By taking apart the shelves and side panels and drying them separately, moisture can escape more effectively. Otherwise, you risk moisture remaining trapped in the joints, which can promote mold growth.
My advice: Ventilate frequently, keep the room temperature moderate (around 18-22 degrees Celsius (64-72°F)), and use professional or at least electric drying devices if possible. Although this is an investment, these devices significantly reduce drying time.
If you don’t have equipment, at least disassemble the unit and stand the shelves upright so air can circulate. Check regularly for odors or signs of moisture.
In summary: Expect at least one week, preferably longer, especially since particleboard furniture takes longer to dry.
Danabla
18 Jan 2020 09:37
Additional Information:
The drying time for a Kallax-like piece of furniture after water damage typically ranges from 10 to 14 days in a private setting without professional drying equipment. It is important to monitor the moisture levels in the material and take early action if signs such as mold odor or swollen edges appear.
It is essential to fully disassemble the furniture. The individual parts should be stored separately and with some distance between them to promote air circulation and accelerate moisture evaporation.
If only ventilation and fans are used, drying can take significantly longer in conditions of high humidity and cool temperatures—sometimes 3 weeks or more.
Additionally, Kallax shelves often have plastic or foil coatings that can trap moisture, which also extends drying time.
Conclusion: A period of 7 to 14 days is realistic, with optimal ventilation tending toward the shorter end. Complete drying, ensuring no risk of mold, only occurs when every component is dry and free of odor.
Layla
19 Jan 2020 16:58
I can completely understand how stressful situations like this can be. Something similar happened to me some time ago: water damage right in the room with the Kallax shelving unit.
refinar schrieb:
“Take the shelves apart at least, stand the individual boards upright so air can circulate.”
That really helped me a lot, even though I didn’t know much about it. I found it interesting that the parts resting directly on the floor took much longer to dry and stayed damp until I lifted them onto small wooden wedges.
I ventilated for about 10–12 days, often and frequently, and also used fans. But the most important thing was to be patient and regularly check if the typical “damp smell” was going away.
What reassured me a lot: this Kallax material combination only completely molds if it is left damp for too long. So if you, as already recommended, regularly check and keep it dry, you should be safe.
If this helps anyone: for me, it actually took about one and a half weeks before I could bring the shelving unit back in and use it without worries 🙂!
