ᐅ How much weight can typical KALLAX shelves actually support?
Created on: 15 Aug 2023 09:17
leoteo53
Hello everyone, I am currently considering getting a KALLAX shelf unit from IKEA and have a question that concerns me beforehand: How much weight can the typical KALLAX shelves realistically support when installed normally and without additional reinforcement?
I am specifically interested in practical experience and official information about how much weight the shelves can handle in everyday use without bending or damage. I want to know if it is safe to store somewhat heavier items like stacks of books, devices, or boxes on these shelves – or if it is better to plan for lighter loads.
Perhaps someone here has reliable practical experience or well-researched material data? Thanks in advance!
pikin
15 Aug 2023 12:01
Danial schrieb:
Experience from forums suggests that 15 kg is a safe upper limit.
That is correct. IKEA officially states 13 kg, with some users reporting up to 15 kg. The MDF board, at 22 mm (0.87 inches) thickness, is relatively sturdy but not designed for point loads. Loads over 15 kg significantly increase the risk of sagging.
Recommendation: Distribute the weight evenly and, if more load-bearing capacity is needed, add additional support beneath the shelves, such as metal brackets or wooden strips inside.
leoteo53
15 Aug 2023 14:26
Thank you for the feedback so far; it has been very helpful.
One more question: Are there any reliable experiences regarding how much the shelves bend when the 15-kg (33 lbs) limit is significantly exceeded? I would like to have a general idea of what to expect if, for example, 20 kg (44 lbs) is evenly distributed. Would that cause only a minor visual effect, or could the shelves suffer permanent damage?
I am also interested in whether frequently removing and reinserting the shelves noticeably affects their stability. Thank you!
Lotizar
15 Aug 2023 15:12
Deflection under a 20 kg (44 lbs) load is usually noticeable and more than just a minor visual effect. This deflection can be several millimeters, sometimes up to one centimeter (0.4 inches), depending on the duration of the load. Over time, this deflection may increase, since MDF is not elastic and handles stress poorly. Permanent damage such as cracks or chipped edges can then occur.
Repeated removal and reinsertion of the shelves can wear down the supporting tabs in the shelf frame. This causes the shelves to sit less securely and makes them more likely to give way or shift under load. Therefore, avoid frequently swapping the shelves if possible.
warrenka57
16 Aug 2023 09:23
Thanks for the assessment, Lotizar! I can confirm this: I also noticed a slight downward bowing over a few weeks, especially under heavier loads. With moderate use, it was initially only a visual issue, but I decided to be proactive and improve the stability.
It’s important to me that the shelves function reliably for years – when it comes to furniture, I prefer to put in a bit more effort during assembly rather than having to fix it again later.
Danial
16 Aug 2023 10:54
Lotizar schrieb:
This bending can worsen over time because MDF is not elastic and handles stress poorly.
Exactly, this material property makes MDF less suitable for everyday use under heavier loads.
It would be interesting to know if anyone here has long-term experience with modified KALLAX shelves—for example, with increased construction depth or the use of reinforcement profiles. I am interested in whether such methods noticeably extend the lifespan.
Siflo
16 Aug 2023 12:30
A proven method to increase load capacity is to insert cross supports or metal brackets under the shelves. This allows the weight to be distributed across multiple support points, reducing deflection by up to 70-80%.
Some users also replace the shelves with thicker MDF or plywood panels to achieve higher load-bearing capacity through increased stiffness.
However, for the original KALLAX system, technically speaking, loads above 13-15 kg (29-33 lbs) without reinforcement can cause issues. Anyone planning to apply heavy loads should take additional measures.
