ᐅ Drilling Through a Timber Frame Wall
Created on: 23 Sep 2020 18:15
ashley
Hello, I need to drill a hole through an interior wall of a house with a timber frame construction. What is the correct procedure? Should I just start drilling through? Or how do I find a suitable spot? Thanks for your tips. Ashley
hanse987
23 Sep 2020 22:10
Or on a mounting bracket for the staircase?
pagoni2020
23 Sep 2020 22:32
Maybe you accidentally drilled into the new Nord Stream 2 pipeline!
@ashley, I hope you’re not serious about asking for advice here in the forum on whether to continue drilling after hitting something inside the wall.
No one can tell you for sure if you should keep drilling.
There could be gas, water, electricity, wastewater pipes, or something simpler. You can only find out on site.
Just as a heads-up: A few months ago, I drilled a hole for a mirror in the bathroom wall. Unexpectedly, far behind the surface, a plumber had installed a water pipe there. Luckily, I was cautious since I wasn’t involved in the original construction.
Two years ago, a colleague of mine hit an electrical cable inside a wall. The electrician had run several cables diagonally, apparently to save wiring.
So, we can’t give you any advice that would guarantee your safety in this situation.
Probably nothing serious would happen… probably!!!
ashley
24 Sep 2020 06:23
I am not asking for any guarantees or for you to know what is behind my wall. Would you prefer to stick with one hole and drill through it "by force," or drill several smaller holes closer together until it becomes easier? In the latter case, you end up with multiple holes in the wall.
pagoni2020
24 Sep 2020 07:28
As others have already mentioned, it could be a beam or a metal bracket or something similar. However, you simply don’t know what material it is or how strong it might be—whether wood, metal, or something else—so your question can’t really be answered. Depending on the material and the drill bit you use, you might spend an hour drilling without making any progress.
In this case, I would definitely look for a spot where you can drill through easily. If the wall structure allows, it might be better to find a place where, after an initial hole, you can insert a wooden rod or something similar all the way through to the other side. That way you can be sure there’s nothing inside that you shouldn’t be drilling into.
