ᐅ Doubling Kallax Doors – Is It Possible Without Screws?
Created on: 7 Feb 2019 09:17
Reben59
Hello everyone, I am considering adding extra doors to my IKEA Kallax shelves by "doubling" them—that is, attaching a second, thinner door onto the original one to change the appearance or increase stability. Now my question is: Is it possible to double up Kallax doors without using screws? I want to avoid damaging the doors or weakening the shelf by screwing into it. Are there adhesive systems or special techniques that can achieve this, or is it generally unrealistic? I would appreciate any tips or experiences!
U
Ulrichta
8 Feb 2019 09:03
Hello, I can add that there are also special double-sided tapes designed for furniture that can achieve considerable strength. However, I would recommend leaving the doors undisturbed for two to three days after bonding before using them. For higher stress, mechanical fasteners are certainly more reliable, but if the goal is to avoid screws, these adhesive methods are a good alternative.
giabau
9 Feb 2019 10:17
REPITAR schrieb:
1. Preparation: Thoroughly dust doors and lightly sand them to improve adhesion.
This is a very important point that is often underestimated. Without proper preparation, even the best adhesive will not hold.
Ulrichta schrieb:
I can add that there are also special double-sided tapes designed for furniture.
Yes, these are convenient, but I mainly recommend them for smaller and thinner overlays. For large doors, there is a higher risk that the edges will come loose. My rule of thumb: the bigger and heavier, the more mechanical fastening should be added.
blapau
10 Feb 2019 07:45
In summary, doubling Kallax doors without screws can work—provided that the adhesive is high quality, the surface is well prepared, and the weight of the second door is not too heavy. However, for maximum security, mechanical fastenings should not be ruled out entirely. A trial run on an inconspicuous spot or with an old door can help determine the best method for your specific situation.
