Jessicam397 Oct 2024 18:37Hello everyone, I have a somewhat unusual question about the durability of IKEA furniture, specifically the KALLAX shelving unit. I’ve noticed that over time the material of my KALLAX seems to be breaking down or at least becoming brittle, and the surface is starting to change. The unit is placed in a rather dry room without direct sunlight, so I’m wondering if this is normal or if there might be a manufacturing defect.
Has anyone else experienced something similar? How long does a KALLAX typically last before visible signs of aging appear? And are there any tips for extending its lifespan? I’m looking forward to your insights and experiences.
warrenka577 Oct 2024 19:08Jessicam39 schrieb:
The shelf is located in a relatively dry room without direct sunlight, so I’m wondering if this is normal or if it might be a manufacturing defect.I completely understand your concern. It’s really frustrating when a piece of furniture that should feel sturdy starts to deteriorate over time. With my second KALLAX, the wood fiber material began to slightly break down at the edges after about 7 years—not dramatically, but noticeably. I think this largely depends on how often the furniture is used and how well it’s maintained. However, to me, this doesn’t seem like a genuine defect but rather normal material wear.
I believe it’s important to contact customer service in such cases, especially if the furniture is only a few years old. Sometimes manufacturers offer warranties that might cover issues like this.
Hello Jessicam39,
Your question is indeed very interesting and relates to a topic that many people do not immediately consider: the durability of particleboard-based furniture like KALLAX.
1. KALLAX primarily consists of particleboard with a paper laminate, which looks sturdy but can become brittle over time when exposed to moisture and mechanical stress.
2. When you mention that the surface seems to be peeling, it could be that the laminate is coming off or that the core material has absorbed moisture – even under seemingly dry conditions (humidity, slight fluctuations, etc.).
3. The typical lifespan is usually around 8–12 years.
My advice:
- Avoid placing direct stress on the edges, which can cause excessive wear on the furniture piece.
- Maintain a consistent indoor humidity level (about 40–60%).
- If possible, use suitable furniture oils or care products regularly, but apply them cautiously, as some may damage the material.
If you want to understand the type of damage more precisely, feel free to describe whether it involves chipping, discoloration, or cracking.
My advice:
Jensson schrieb:
KALLAX mainly consists of particleboard with a paper coating, which looks sturdy but can become brittle over the years due to moisture exposure and mechanical stress.I’d like to jump in with a provocative comment: don’t expect too much from this piece of furniture. It is an inexpensive product, not designed for long-term durability. Sure, IKEA offers good designs at affordable prices, but "falling apart"? To me, that sounds more like poor assembly or deliberately short product lifespan.
Why would anyone expect a shelf to last over 10 years, considering IKEA focuses on mass production and quick availability? If you value longevity, you need to invest more—that’s just how it is.
Also, I wonder if your shelf has been treated incorrectly. "Falling apart" isn’t really a usual term for wood-based materials. Maybe it was exposed to too much moisture, the wrong cleaning agents, or mechanical damage?
I would like to add the following: KALLAX shelves are actually made from coated wood particle boards, which can show natural signs of aging after several years of use.
Here are a few specific points that might help:
- The material rarely breaks down or disintegrates, but the paper coating can peel off or the surface may become roughened.
- This especially happens when moisture combines with mechanical stress. Even if the room is dry, increased humidity during certain seasons can cause problems.
- For longer durability, I recommend not overloading the furniture and protecting common stress points with protective film or felt pads.
- Treating damaged areas directly, for example with appropriate touch-up markers or repair kits, often helps stop the process.
- If you believe it might be a warranty case, you should check the purchase date and condition, although IKEA generally offers a 10-year warranty on KALLAX.
I hope this information is helpful. Feel free to ask if you have any further questions.
