ᐅ Do you have any experience using faux leather as a covering for the KALLAX?
Created on: 28 Feb 2022 08:43
MAUFRANKHello everyone,
I am currently planning to get a KALLAX shelf unit and am considering covering the outer surface with artificial leather to make it more durable and give it a higher-quality appearance. Do any of you have experience with using artificial leather as a covering for the KALLAX? I am particularly interested in aspects such as durability, maintenance effort, appearance after extended use, and how well the artificial leather adheres to the wooden or particleboard surface. Has anyone got tips on the application process or encountered any issues?
I would really appreciate it if you could share your experiences, including any recommendations for suitable products or techniques. Thank you in advance!
Sinan-meo28 Feb 2022 10:35MAUFRANK, I actually implemented a similar idea, but with a different shelf. Faux leather generally adheres well as long as the surface is clean and smooth. It is important to use an adhesive that is specifically designed for faux leather and wood – many people use spray adhesive or contact cement.
Regarding durability: faux leather wears out somewhat faster under heavy use than genuine leather but does not tend to tear and is easy to maintain. For the shelf, I would recommend placing a thin layer of padding under the faux leather, which significantly enhances the feel. Maintenance is straightforward – usually just wiping with a damp cloth is enough.
MAUFRANK schrieb:
I am particularly interested in aspects such as durability, maintenance requirements, appearance after prolonged use, and how well the synthetic leather adheres to the wood or particleboard surface.I also consider these to be key points. From my own experience, synthetic leather can start to fade or become brittle after just a few months of direct sunlight exposure. I once tried upholstering a bench with synthetic leather, and after about a year, I noticed small cracks developing.
Therefore, for a shelf in areas that are frequently touched or exposed to light, I would opt for high-quality synthetic leather. Maintenance is straightforward, but handling it with care definitely helps.
Sinan-meo schrieb:
Artificial leather generally adheres well if the surface is clean and smooth.That may be true, but I wonder how durable that adhesion really is. Wood tends to warp slightly over time, and particleboard is more susceptible to moisture. This could lead to delamination, especially at the edges.
Furthermore, we should critically consider whether artificial leather is truly a sensible aesthetic choice for furniture surfaces in high-exposure areas, given that it tends to show wear after just a few years. Perhaps it is merely a visual compromise that lacks long-term sustainability?
ODINFLO schrieb:
Maybe it’s just a visual compromise that isn’t very sustainable?I agree! If someone thinks that faux leather somehow "upgrades" the KALLAX, they should consider the cost and effort of using a real upholstery. The durability of these synthetic covers is often overestimated.
To me, it feels more like a quick fix for "making it look more sophisticated" without thinking about long-term consequences. But the whole KALLAX design thrives on its simplicity. I believe it doesn’t belong wrapped in faux leather. That would feel like overcharging customers.
If you do it yourself, use a high-quality, flexible spray adhesive. Make sure the surface is clean and dry before application. Seal tear-resistant edges. Maintenance: wipe with a damp cloth, avoid harsh cleaning agents.
Faux leather lasts well if properly glued and not subjected to constant mechanical stress.
